No brakes on the studebomb
Discussion in 'The Hokey Ass Message Board' started by edweird, Oct 8, 2012.
  1. edweird
    edweird
    nova front disc, ford explorer rear disc. gm master cyl.manual. what am i doing wrong!
  2. tfeverfred
    tfeverfred
    Dude, you're going to have to give more info.
  3. edweird
    edweird
    lines are all plumed, no air seems to be in the lines. but ya gotta mash like hell just to stop it.
  4. edweird
    edweird
    can ya see he master cyl. in this pic.
  5. deto
    deto
    What's the mc bore? With the volume needed for 4 wheel discs it might not be enough? Does it take a lot of effort to stop or a lot of pumping? What's the pedal ratio? Prop valve? Residual valves?
  6. servi53
    servi53
    need power brake booster for discs generally, if I remember correctly
  7. manyolcars
    manyolcars
    was it working before?
  8. beachbum jim
    beachbum jim
    from Loris, SC
    Do you have any pedal Ed??? Is it a new master? Did you replace all the brake lines??? How did you bleed em? The way I was taught was to set the car up on jack stands, fill the master res. with fluid, then open all the bleeders. When the fluid starts freely running out, tighten bleeders. Refill master and you should be good to go. This process can take a while to work as any air bubbles will have to work their way through the lines. Just be patient. I was also told to NOT pump the brakes when bleeding as this can cause more bubbles to form. Just apply steady pressure as someone else opens and closes the bleeder.
  9. beachbum jim
    beachbum jim
    from Loris, SC
    oops nevermind!!! What is the MC bore size?
  10. Royalshifter
    Royalshifter
    Moderator
    Be sure to have about 1/16 to 1/8 play in the plunger rod be for it plunges and power bleed it?
  11. edweird
    edweird
    i dont know, what should it be?
  12. trollst
    trollst
    Disc brakes require more pressure to operate than drums, I'd suggest a power booster, or get used to high effort on the pedal.
  13. beachbum jim
    beachbum jim
    from Loris, SC
  14. edweird
    edweird
    it takes alot of effort to stop it. dont know, dont have one, dont have them either.i was told i didnt need all that with a swinging pedal.i'm not a brake man, but i will figger this out!
  15. edweird
    edweird
    ithink if i use the ford explorer mastr cyl and boostr, i'll be on the right track. thanks yall.
  16. Royalshifter
    Royalshifter
    Moderator
    My 32 coupe has disc drum and no power booster...stops on a dime.
  17. MISCONSTUDE
    MISCONSTUDE
    Ed, I've got a 1" bore master cyl. with my disc/drum set up on MISCONSTUDE. I spent a lot of time talking to the people at SSbrakes. They were very helpful. The ratio on the pedal has a lot to do with pedal feel.
  18. Da Tinman
    Da Tinman
    try swapping the lines on the m/c. sounds stupid but it fixed the wifes falcon.
  19. mgtstumpy
    mgtstumpy
    Bench bleed the MC beforehand. All that is left is doing the lines. Start with the wheel furthest away from MC and then the net closet and so forth and so on until all 4 wheels have been bled.
  20. tubman
    tubman
    I also have a couple of cars (OK, 60's Corvettes) that have non-power 4 wheel disc brakes. They take a little extra effort, but once you get used to them, they seem normal. They probably weigh just about as much as the Studebaker.
  21. edweird
    edweird
    according to master power brakes co. i may need to use the ford explorer master cyl. and booster. they say it has a longer piston stroke to feed the rear disc properly. i'm calling them today.
  22. make sure your bleeder screws are on top on all four calipers. sometimes it is just a right-to-left screwup.
  23. deto
    deto
    If it takes alot of effort to stop it, and you have a firm pedal, you're gonna need either a booster, or a higher pedal ratio.
