Customs School me on door poppers...
Discussion in 'The Hokey Ass Message Board' started by Ryan, Oct 10, 2012.
  1. Ryan
    Ryan
    ADMINISTRATOR
    I know, elementary question for most... But I've never had a car with shaved handles and have always figured poppers were just an added complication that I don't need in my life. But, I sort of want to shave the handles on my Rivi.
    So, what's the best way to go about this both electronically and with a mechanical fail safe?
    Be easy on me... I'm a virgin.
  2. Anderson
    Anderson
    Do a search.
    :D
  3. msalamanca
    msalamanca
    Cl***ic!!!!!!!
  4. falconsprint63
    falconsprint63
    from Mayberry
    now that's playing with fire :D
  5. zkilla396
    zkilla396
    from Peoria, IL
    My dad did a set on his '50 chevy sedan delivery; seems like he had them installed in a weekend or so, nothing too hard. Few wires need to be run and you use a remote fob like modern cars have for locks. Seemed like it was fairly reasonably priced as well.
    I'm not too sure on the mechanical fail safe though....sorry.
  6. Thom Mead
    Thom Mead
    That is a cl***ic response, however I too would like some info on this. I have shaved door handles on my '50 and count on the reach through the window method of opening the doors. Functional, but not the best idea. Someone pleae show us how to do it.
  7. Doctor Detroit
    Doctor Detroit
    I knew if I just waited for someone else to ask this same question, I wouldn't have to catch the hell.
  8. 56 ford custom
    56 ford custom
    from Socal
    Priceless!
    Ryan,
    My old 51 had shaved handles and poppers, the previous owner had a pull handle uder the hood that would open the drivers door in case there was an issue. You can hide it anywhere.
  9. K13
    K13
    I have always wondered if the latch portion is in the door how does the cable get routed to wherever you end up placing it? Do you just run it through the door jamb with a flexible conduit like a wire loom?
  10. 55 dude
    55 dude
    any setup you use upgrade the cable to larger size and be sure if you have to go around a 90 degree curve with cable use some copper tubing. as far as brand to use: the stock O.E.M. ones from the rear doors of vehicle from your local wrecker. Grab any wiring and switches.
  11. [​IMG][​IMG][​IMG][​IMG][​IMG]
  12. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Not traditional.
    (running and hiding)
  13. VoodooTwin
    VoodooTwin
    from Noo Yawk
    That's one way to do it. The other way is to use electrical contacts on the jamb and the door, so that when the door is closed, the electrical contacts "make" and you have power.
  14. msalamanca
    msalamanca
    I saw in a search on here before that you can use a bicycle brake cable for the manual. Route it thru the the door into the wheel well
  15. flatheadpete
    flatheadpete
    from Burton, MI
    I shy away from cables as an attachment between the latch and 'popper'. A rod in a straight as possible path is way stronger. As for a fails safe....that's where a wire comes in. From the latch thru sheet metal and a key ring to grasp and pull. If I can do it, anyone can!
  16. wallyringo
    wallyringo
    x2 i need this info to please.
  17. deto
    deto
    Oh boy... Well x2 on the cable. My friend ran his into the engine compartment as well.
  18. slddnmatt
    slddnmatt
    I call poppers the spring loaded ****ons that pop the door out so you can grab ahold of it;). for the selonoids I would use the rod between the latch and selonoid as mentioned. On the old latches i usually run the heavier pounded selonoids. A rivi latch might be a bit smoother operating.
    Im installing a mechanical fail safe pull on a 40 merc tomorrow. they can be fun, Im using wire rope through a flexible cable line like a bike hand brake or you can get fancy and bend up some brakeline and run it through that. the biggest issues i've had are when the door pivots open on some applications (like this merc) the door pivots in a close radius and if you have the cable to tight it really pulls and binds the cable, and to loose it doesn't do a damn thing. the straighter the line the better the pull..
  19. Not to difficult with bearclaws, did it on the '50 coupe and in the process on the '36 PU, Rocky Hinge has a pretty sweet setup. If you are keeping the stock latches it may be more interesting. The mechanical safety cable is definately a good idea........btw is that Rivi Hamb freindly?;)
  20. Sinister
    Sinister
    from Oregon
    Remote gas door and trunk popper cables are already sheathed with the nubbins on the ends. Just thinking out loud...
  21. choptvan
    choptvan
    auto loc has some great stuff. poke around on there for a bit. They have a cable safety release that has a lock built into it. So your car is still secure in case someone finds that cool little cable. If you do electronic, I rec doing a battery cutoff switch accessable to you outside the car. Just leave the stereo memory hot. It will kill the rest. No getting in at all then. Also. last thing. If you shave everything, and the battery is in the trunk, relocate some jumper posts under the car where you can get a set of cables on them. just for that BS incident that could just happen on a day, when the HAMB is down, someone made a post about another damn body swap or R/R, and you just have to get to the office. Just sayin.
  22. hotrd32
    hotrd32
    from WA
    Well if you put the ****on under the running boards...the tip of your shoes get dirty....
  23. nutbush
    nutbush
    from Texas
    *edit*
  24. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Don't **** the Rivi up trying.
    Try on another POS car until you get it right.
  25. fastcar1953
    fastcar1953
  26. thesupersized
    thesupersized
    door solenoids are period correct...a lot of old customs had them.
  27. fastcar1953
    fastcar1953
  28. big creep
    big creep
    early vw starter solenoids work best, and do, do a cable through to the firewall as a secondary if it fails. and make sure you can lock the hood too. yea its a lot of work but its well worth the look if you want it.
  29. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Thats why we use magnetic switches on top of relays. You can hide the switch aywhere, just swipe a magnet near it, and they open. I have had guys crawl all over the cars to find a ****on :D
  30. big creep
    big creep
    ryan this may help? dont use the autoloc set. but this guy gives you an idea of what to do. but if not you will laugh at this dude.
    http://youtu.be/VmFDzA5ohyc
