linkage help 63 galaxie
Discussion in 'The Hokey Ass Message Board' started by ashebaba, Oct 11, 2012.
  1. ashebaba
    ashebaba
    from Wisconsin
    Hi, New to forum but need help...63 galaxie, was 352 now 390, .10 over, new crank and bearings, edlebrock alumium heads, erson rolling rockers, edlebrock 2105 package ..problem is edlebrock has no linkage set up. Anyone have ideas, done this and have pics--in short..HELP
  2. ecam
    ecam
    Do you have any linkage? Does the manifold have a boss to mount factory linkage to? Speed shops will have universal cables, some are carb base plate mounted. Lots of the stock stuff had just the rod (through the firewall) and a link to the carb.
  3. ecam
    ecam
    Linkage like this? Auto or manual?
  4. ashebaba
    ashebaba
    from Wisconsin
    have all the stock stuff from both 390 and 352-AND bracket for manifold from edlebrock for 64 on up, but tod does not match up-so guess just need to figure it out, was hoping someone would have done this and could provide pic
    thanks for the quick reply
  5. ashebaba
    ashebaba
    from Wisconsin
    that is just the pic I need--A BIG THANK YOU
  6. carbking
    carbking
    If auto transmission, Carter used to supply a different aftermarket AFB specifically for Ford. Part number was 9627s superceded by 9637s. Both carbs had the special kickdown lever on the throttle to make the auto tranmission shift.
    Jon.
