Edelbrock 600 cfm electric choke. Do i hook it to a constant hot wire when key is on or do i hook it to a seperate switch for normal operation ?
Powering from the ignition opens the choke whether the engine is running or not. Sometimes that's ok, other times it's a problem. If you have an alternator, and that alternator has a stator terminal, powering the choke from that terminal is a better option. The stator terminal only produces current when the alternator is producing power, so the choke only starts opening when the engine is actually running.
Yes. All electric chokes work essentially the same. 12V makes the spring hot and air being ****ed across it cools it down.
