Projects Recreating the jesse lopez coupe
Discussion in 'Traditional Customs' started by jivin jer, Aug 18, 2012.
  1. jivin jer
    jivin jer
    Well, that wasn't the case then, here (?), we shall see.
  2. Rickybop
    Rickybop
    Awesome project, JJ. You tell a good story too...lol. You have inspiring p***ion and dedication, and you're able to express it. Thanks for the quality entertainment. Gonna be so cool to see this custom come together. Good luck!
    #%#%* rust. #&%!* "inspector"...:rolleyes:...lol.
  3. jivin jer
    jivin jer
    DUM DAT DAT DUM DAT DAT DUM. You get the idea. This is a better pic of the lower trunk opening lip.
  4. SIC98
    SIC98
    And so it begins, another journey with a beautiful ending! Can't wait to see the Lopez coupe next to JR's car in your expanded diorama Jerry !!!
  5. VonKool13
    VonKool13
    Even if that color is wrong in the pic, that is one BEAUTIFUL green!
  6. jivin jer
    jivin jer
    OK, I kept thinking "whats the least that I have to replace?"
      465.7 KB
  7. jivin jer
    jivin jer
    I kept havin' to order (and waiting) more parts.
  8. daddio211
    daddio211
    Just read the latest issue of TRJ. There's a two page shot of Jesse's coupe.
    Sent from my DROID device using the TJJ mobile app
  9. koolkemp
    koolkemp
    Read my build thread....you will appreciate how solid your car is lol 1 Looking forward to following your progress especially the chop.
  10. jivin jer
    jivin jer
    A look from the top.
      495.1 KB
  11. jivin jer
    jivin jer
    Koolkemp, I did check out your build thread. What can I say? Your a monster! I will talk about all this talent that's "out there" and how it relates to what I'm doing on this build. Down the road.
  12. LeadSledMerc
    LeadSledMerc
    Awesome choice for a build...I can't wait to see this progress. :cool:
  13. jivin jer
    jivin jer
    Here's a look at the new rocker panel (inner and outer).
  14. jivin jer
    jivin jer
    L 1/4 inner and outer. A really cold weekend that helps with the heat that's building under my collar over this rust damage that was visible/obvious. The Kustom Kar GOD is reminding me that "all things WORK TOGETHER for the good to those..."
      387.2 KB
      500 KB
  15. rob-redm
    rob-redm
    Looking good Jer !
  16. koolkemp
    koolkemp
    Looking great !
  17. PeteFromTexas
    PeteFromTexas
  18. PeteFromTexas
    PeteFromTexas
    Do you have a parts lost going?? Anything that you know you will need?? I can start digging
  19. jivin jer
    jivin jer
    Thanks Pete for the inquiry. I've done well on the first list post# 24. My needs now are a '46 front bumper bar and gaurds (I have the brackets), rear gravel deflector, trunk lid, Spalding ignition, small SW gauges-oil,temp and a mech tachometer (I think they're 2 1/4" diameter faces, and a '49-'50 Mercury accessory steering wheel.
  20. Hot Rod Cowboy
    Hot Rod Cowboy
    Good luck with the parts list and the build. I will be eagerly watching this progress.
  21. I know you're not happy doing the rust repair, but your photos are going to help me a lot when I get into my '41 in the spring. Thanks for posting them.
  22. PeteFromTexas
    PeteFromTexas
    I might have the gauges. Do you have a pic of the type you need?
  23. jivin jer
    jivin jer
    Not quite yet. I have to run a pic past Jesse to see what was there.
  24. jivin jer
    jivin jer
    I took this piece out of the L 1/4 that was removed to make a L door repair panel. It had the same contour.
      517 KB
  25. williebill
    williebill
    Looks great so far.. good luck
  26. jivin jer
    jivin jer
    The drivers floor looked like it had a dime size hole.
      526.9 KB
  27. koolkemp
    koolkemp
    Wont be long and she will be ready for a bit of a hair cut :D
  28. jivin jer
    jivin jer
    I needed a piece that had a lip on it. I found it on my '50 Ford parts car. This is a cowl piece.
      500.8 KB
  29. Michelley
    Michelley
    Hello Jerry!
    Been so busy this whole year
    with a few cryptic book projects
    (some kar, some other).
    When not procuring & restoring
    rare vintage rides and speed parts,
    this is how I’m burning the sunrise oil.
    Haven’t even gone on a road trip longer than a day or two trip.
    Making only the quintessential telephone calls & emails.
    Always driven by the administrative self-discipline
    of the self-employed…
    In the interest of historical authenticity,
    did you know,
    Jesse told us that the back window was composed
    of a sheet of 1/4" aircraft grade Plexiglas,
    that he got to bend and conform to the convex ellipse,
    because of complications cutting tempered gl***.
    He also mentioned that he was at a s**** yard
    and noticed a sliding door channel of polished aluminum
    with a particularly graceful curve to it,
    that shortened to approximately 10” with the ends filled,
    made a really cool rear license plate light.
    That’s what he used.
    Jesse has a clever eye.
    He gifted us these
    original Marcia Campbell snapshots circa 1950-51,
    that she gave him,
    of the Bill Taylor ’49 Chevy convertible.
    Jesse is as elusive as a snowy panthera.
    These veterans can be skeptical,
    indeed you are cultivating their trust.
    Keep the Faith!
    By the way, Keen Kent Vikmo,
    I noticed the personally autographed pic of Jesse
    that David had him sign for you.
    -Michelley
    Atwater Mike likes this.
  30. jivin jer
    jivin jer
    Thanks Michelley, I knew about the back gl***, I hav'nt gotten to the lic plate light. This will help. I'm learning that it's valuable to also get perspective's from those that were "around" then as well.
