SCTA legal cage + padding + helmet = ??"
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Oct 14, 2012.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    I know a few here own LSR projects or finished cars. If any of you get a chance could you measure from the top of your cage to the top of your head when you're in it and suited up?
    Ever seen an A coupe with a Gurney bubble? :)
  2. RichFox
    RichFox
    Not the best picture. In the eyes at El Mirage. An inch or maybe two. I scrunch down at tech.
  3. 38FLATTIE
    38FLATTIE
    from Colorado
    Kevin, no one on our team has more than an 1" clearance. I'm the tallest at 6'3", and have to scrunch down to get any clearance!
  4. Mazooma1
    Mazooma1
    don't know if this will help, but......somebody will jump in here pretty soon that has a rule book..
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    Thanks but... Not looking for clearance between helmet and cage — literally want the (ballpark) measurement from top of head to top of cage when seated. As in, will I need to add a blister to fit a cage when looking out of the windshield.
  6. Mazooma1
    Mazooma1
  7. Wasnt Ryan going to put Guerny bubbles in his coupe at one point when it was going to get a mega chop and still fit is long lean frame inside of it?
    I got nuthin to measure for ya kid, I wish I did.
  8. Kevin Lee
    Kevin Lee
    Super Moderator
    Man... maybe I need to go about this by asking a different question.
    How much vertical distance is there between your eyeballs and the TOP of your roll cage when seated in your car?
    Or maybe, How thick is the typical Snell approved helmet? (I might be able to rough it in from there)
    I'm dealing with a heavy chop and low roof crown – Just trying to figure out if I'll need to add a bubble to the roof or cut eyeholes in my firewall.
  9. 38FLATTIE
    38FLATTIE
    from Colorado
    Kevin, 3.5". That's with 1-5/8 tubing, 1" of padding, and very little helmet to pad clearance.
    Hope this helps!
  10. Kevin Lee
    Kevin Lee
    Super Moderator
    It helps, so I'm still trying to find the thickness of a typical Snell helmet to get me in the ballpark then.
    Thanks.
  11. RichFox
    RichFox
    There is a Studebaker (ex-Burklands) with the roll bar sort of molded into the roof. In my '32 which was not chopped but was channeled the width of the frame I had head room. Don't have a real inches measurement for you. I guess you will have to sit in the car and measure your exact clearances. I'll put my Bell helmet at 2 inches thick, but that is a rough measurement and I don't want to cut it in half for a good one.
  12. NV rodr
    NV rodr
    from Reno, NV
    Kevin this would be more helpful posted on the landracing.com site. There are some really good photographers on there and more racers that have had to face the same issues. Just like the HAMB but land speed racing oriented. Tons of helpful people that have p***ed tech and set records. Really never met someone at Bonneville that wouldn't help in any way possible. Great folks and many SCTA officials and tech guys answer questions in the forums.
  13. 38FLATTIE
    38FLATTIE
    from Colorado
    I agree with Richj- about 2". So that makes it 5.5" for a VERY tight fit, minimum.
    Kevin, what kind of car/cl*** are you building for?
  14. Ole don
    Ole don
    Is there such a thing as a typical snell helmet? I went to Speedway expecting to be fit for a helmet from the catalog at $189.00 The second one off the shelf fit good. The hole in front wasn't big enough for my gl***es to fit through. The Bell I walked away with was $389.00 Expect to stumble when heading to the salt.
  15. Candy-Man
    Candy-Man
    Remeber the "HANS" Device you wear. I leave my HANS buckled up when exitting my Belly Tanker, however; I put quick release system on the sides of the helmet which releases the tether strap, allowing the HANS Device to fall backwards. Quite often the top of the HANS hits the front hoop when you are exitting your car. This obviously depends on your roll cage style, etc....
  16. Reverborama
    Reverborama
    from Minnesota
    I believe the answer to your question is that however you do it, the head has to remain inside the plane of the roll cage at all times. I don't think a bubble like the one on that GT would p*** tech at Bonneville. If that guy's head is up in that bubble, or it can get up into that bubble, it is outside the plane of the roll cage. I'd make a drawing of what I wanted to do and email it to the chief car inspector before I spent any more time at all thinking about it.
    Contact information is here: http://scta-bni.org/contact.html
  17. firingorder1
    firingorder1
  18. Mr48chev
    Reverborama pretty well nailed it when he said that SCTA wouldn't allow anything like that Gurney bubble, That was early 60's technology and I doubt any sanctioning body would allow it now.
    Remember that you still have to be able demonstrate that you can exit the car on your own in X amount of time or less too.
  19. titus
    titus
    I would think your best bet is to get the helmet your gonna use, then you know for sure, i would wonder if all schnell approved helmets are the same thickness above your head, i have a snowmobile helmet that i bought 2 years ago thats schnell approved and could measure that if it helps get a average measurement.
    JEFF
  20. titus
    titus
    I think you guys are missing what Kevin is saying, hes gonna put the rollcage "thru" the roof and put a gurney bubble to cover it
  21. might as well buy the helmet before you build the cage ??
    channel the seat . SINK IN TO THE CAR. RATHER THAN BUILD UP.
