what radiator hoses do you use for a 32 with smallblock chevy
Discussion in 'The Hokey Ass Message Board' started by carcrazyjohn, Oct 10, 2012.
  1. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Well thats my question.Looking for black rubber ,No billet ****........
  2. 327-365hp
    327-365hp
    from Mass
    Here's what I use.
    Lower... NAPA 7253
    Upper for 45* water neck... NAPA 7575 (Gates 22417)
    Upper with straight up neck... Gates 21954
  3. big duece
    big duece
    from kansas
    Stock pump or the zips water riser??
  4. 327-365hp
    327-365hp
    from Mass
    You're welcome. :rolleyes:
  5. garcoal
    garcoal
    you are leaving our question fairly vague. small blocks differ and so do radiators
  6. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Its an aftermaket with a small block ,Used a 87 chevy van waterneck....
  7. nochop
    nochop
    from norcal
    I used a Mopar straight up tstat housing. Cast iron not chrome plated pot metal ****. Made for a nice bend in the hose
  8. Tony
    Tony
    I used 57 Chevy 283 upper and lower on my old 32 before i put the blower on it. My thermostat housing was straight forward and up at a 45 degree angle, and the rad was a center outlet on top.
    Had to trim them a little, but they worked perfectly.
    Tony
  9. Go to NAPA with the measurements of both ends and they should let you look at their stock and find some thing that fits. That is how I found the hose for my 32. be open minded you might have to shorten one
