Projects 41 willys help
Discussion in 'The Hokey Ass Message Board' started by deerchooper, Oct 14, 2012.
  1. deerchooper
    deerchooper
    hello everyone
    my buddy got a gl*** 41 willys.
    the ppl he got it from, did not
    1. hang the doors
    2. finish the floor
    3. install body framing.
    so i would like to help him get past this hump in the road.
    what can i do with the thin gl*** floor?
    support for the body at a and b pillars and firewall?
    where can we get door hingess on the cheap? he would like oem style
    thanks in advance
  2. Weasel
    Weasel
    Lay some more mat on the floor to beef it up - your local boat supply should be able to help with materials. You'll need to laminate in some body bracing - wood or steel too. OEM style door hinges from www.willysreplacementparts.com + a bunch of other stuff your buddy will be needing....
  3. drumyn29
    drumyn29
    I think I have some door hinges very much on the cheap.
  4. donbatey
    donbatey
    Look up Langys thread " my willys coupe build" for all the info/ inspiration you need.
  5. rustednutz
    rustednutz
    from tulsa, ok
    Or you could just ship it to me and I'll deal with the issues. ha ha Good luck with the build. Share some pics in a build thread.
  6. deerchooper
    deerchooper
    you do? let me know very interrested.
  7. deerchooper
    deerchooper
    ive been watching it.
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, Steve's (Langy) build is a wealth of info and he reinforced his in all the key places so things like doors hang well.
    A lot of these bodies are what they call "race weight" which basically means thin fibergl*** vs a heavier layup on a "street weight" body. So it becomes a lot like building a T bucket body, only bigger, where you have to add a framework and some extra thickness in some places to make it strong enough for street use.
    If you have never done any fibergl***ing, go to the library and get a book or two on building and repairing fibergl*** boats. I have done a lot of gl***ing in my life, but I have a couple of books in my collection that taught me a lot I didn't know.
    As weasel said, go to a good, old fashioned marine store (not one of the so called Discount Suppliers with prepackaged everything) and buy your mat, resin, acetone, and other supplies in bulk. You will be using more throwaway brushes, vinyl gloves, stirring sticks, plastic cups, acetone, and other supplies than you can imagine. But after you do a little laminating you will think you have done it forever, fibergl*** is a very forgiving medium........but VERY itchy! Cover up well and blow the dust off frequently.
    Don
  9. deerchooper
    deerchooper
  10. 1/2done
    1/2done
    from Ohio
