Help a fellow HAMBER OUT!!! Welding done by shop!
Discussion in 'The Hokey Ass Message Board' started by Mr.Dickies, Oct 16, 2012.
  1. Mr.Dickies
    Mr.Dickies
    Okay guys check out these professional welds. These came from a shop that someone paid good money to have their front clip done! The thing about it is this is the redone work! I won't name the clip, shop or vehicle. If the owner want to tell who what where I will let him. He came over my house to have me check out the "FIXED" truck. I got under and was in shock. I will call the clip a Mustang II not to give it away.
    Looking up at the bottom of the frame. This is their plate for the front part where the they added the " mustang II" it's not a Mustang II but if I say what it was people might know the person who did the work. I will let the owner chime in if he wants to. As you can see they didn't even finish welding the plate all around. you can stick something into the hole nothing is under it. I think the welds speak for themselves.
    The "Mustang II" clip was attached to a bent frame so to make up for it they welded 3/8 round rod to both sides to close the gap!
    This is the boxing plate not welded 100%! looks like they forgot to finish welding?
    Shock mount they didn't fit without re shaping them so they filled the gap with weld. The frame bent so now the shock when at ride height rubs the frame!
    Boxing plate. Not completely welded and weld puddle wasn't hot enough.
    P***enger side shock mount welds speak for themselves. Also not primed or painted.
    The other side plate welds. Note that the 3/8 rod has more of the sides showing because the gap on this side is larger.
    I went to the shop with the person and bust out my iPhone. I ask him if he has been under the vehicle. He says "No". I aked who did the welding because I have to show him what it looks like He said he did. Which confussed me. Either he was under it or not. Anyways. I start showing him the welds and asked if he would let his children ride in this " vehicle" did he feel it's safe. I have rode in it by the way. The frame is bent at least 3/4 of an inch. just by putting a tape measure on it and measuring things. and to the eye it looks real off to. Once I start showing him the pictures he gets in my face and starts saying he's going to kick my *** don't put down his work blah blah blah. You know the type. To be honest if I didn't just have s***ches removed and could make a fist I would have fought him. The person and I step away from each other. The whole time he is yelling at me turns to the person says "he'll make it right but your friend can't talk **** about my work!" ARE YOU KIDDING ME? To be honest I have never seen such bad work. It makes the welds on my wife's car before we met look like Brian B*** did them. This shop is for the 3rd time going to "fix" this vehicle. SO MY QUESTION IS TO YOU GUYS WOULD YOU HAVE THEM WORK ON YOUR CAR OR TRUCK, WHAT WOULD YOU DO? WOULD YOU FEEL SAFE RIDING OR DRIVING THE VEHICLE? WHAT DO YOU THINK OF THE WORK? WELDS? ECT
  2. K13
    K13
    None of your pictures seem to have worked.
  3. pictures no worky
  4. LeftCoastErik
    LeftCoastErik
    Links dont work. Hope this isn't Blake's Truck...
  5. afaulk
    afaulk
    Uh, I cant acces your pics
  6. Mr.Dickies
    Mr.Dickies
  7. Gerg
    Gerg
    man thats ugly!
  8. Last edited: Oct 16, 2012
  9. JD Miller
    JD Miller
    Damn, that ****s. That guy obviously cant weld and is a beginer, never took a welding cl*** whats so ever
  10. LeftCoastErik
    LeftCoastErik
    How do these guys keep taking people's money???!! I have been trying to stick metal together for about 18months or so, on my on stuff0-and not on anything structural. Makes my ****ty welds look like Jesse James did them comparatively...Unreal.
  11. 1/2done
    1/2done
    from Ohio
    It looks like it was welded with a lamp cord.
  12. im gona go with a new shop...
  13. K13
    K13
  14. 1964countrysedan
    1964countrysedan
    from Texas
    DUDE!!!
    I haven't welded in over twenty years, but am confident that I could beat that with an old Lincoln 225 arc welder.
    As you have pointed out, it is much more than just the welds...
  15. HamD
    HamD
    I've welded a small amount in my life.
    But enough to know that's not good enough work for safe structural / ch***is work. With the stuff you've pictured, there is too much question of whether he knows how to ***ure proper penetration.
    And I'll step back and let the pros take it from here.
  16. deeddude
    deeddude
    The guy who did that work will probably get a TV deal. I get so sick if seeing shops butcher cars up and do this type of work. That guy didn't even try to weld.
    He got mad at you? I would let everyone know who this guy is, and then maybe the real professionals could make a decent living. Very poor craftsmanship.
  17. Atwater Mike
    Atwater Mike
    This is like an anonymous hot tip. What's this 'mystery shop owner's' status, HAMB Alliance member or something?
  18. Mr.Dickies
    Mr.Dickies
    When I showed him a weld where they missed the whole side of the bracket with a cold weld and it wasn't touching the shock bracket he turned to the person and said I will have the welds x-rayed if it will make you feel better.
    It's not my place to say the shop or who's vehicle it is. If you are getting air bags done in the Los Angeles area PM me I'll tell you whether or not if it's that shop.
  19. smarg
    smarg
    I've read the story about this guys truck a couple times.
    Sometimes paying a cheap shop rate gets your car ruined.
    I highly doubt the fool or "fools" that welded that together have any certification. If they do they got it at kinko's..
  20. JD Miller
    JD Miller
    Looked at those pics again
    My dog can weld beter than that.
    That isnt even welding. That is a joke
  21. K13
    K13
    HAHAHA who needs a xray you can already see through half of them already HAHAHA!!
  22. fenderless
    fenderless
    from Norway
    Would not p*** the DMW here!
    Sorry but Stevie W would have done this better!
  23. mechanickeith
    mechanickeith
    WOW!! I was doing better than that half an hour after I picked up a stick welder in my freshman year of highschool.
  24. ryno
    ryno
    **** that
    If this someone is doing customer work,please by all means let us know so some else is not screwed also.
    If this is blakes truck,I'd like to hear his story. I thought I read somewhere no limits was helping with it and he was happy. I could be wrong.
  25. oj
    oj
    That is just priceless! The guy drove it to your house? thats what you said, right? Then he has what he deserves. He accepted the work and is driving it.
    The owner needs to share responsibility for this mess - he might be a great guy and a best pal - but when you comminssion work to be done it is your job to see it is done proper. That work (there has been similiar work shown on here as well) should never have left somebodies' shop, to drive with those welds is irresponsible.
    The shop that did the work should not get an oppertunity to correct that mess as it is obvious they are incompetant. They need to stand for the bill to have the work properly done in a competant shop.
    I have no sympathy here for the owner or the guy taht did the work, pathetic.
  26. Go read my link...............the "fab" guy even posted on that thread.
  27. brad chevy
    brad chevy
    At least post the name of the shop,doesn't matter what the guy that did the weldings name is if the shop lets **** like that out the door ,the whole operation is guilty.
  28. propwash
    propwash
    from Las Vegas
    wow, that is frightening. How many cars has this welder worked on that the owner didn't bother to check the finished work? One can only speculate.
    As posted earlier, I could weld better than that the second day of "Farm Shop"
    dj
  29. Mr48chev
    That does rather look like the welds on the pieces of s**** that first day AG shop welding students did. Or about the same skill level involved.
  30. skyrodder
    skyrodder
    did he go to the cheapest "shop" he could find? you get what you pay for
