Where can I get an "inline" rod end/heim joint similar to these???
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Oct 16, 2012.
  1. tlmartin84
    tlmartin84
    from WV
  2. Atwater Mike
    Atwater Mike
    Technical term is 'spherical rod end'.
  3. what size? Speedway should have them
  4. Why not just get them from mcmaster carr.
    Tim
  5. ryno
    ryno
  6. Old Tin and New Tin
    Old Tin and New Tin
    Spherical rod end/heim end. Depending on what size you need and what type of material you want it made from, you should be able to find them at your local speed shop or circle dirt track shop. It is going to be hard to beat the price and service if McMaster Carr has what you are looking for.
  7. Crankhole
    Crankhole
    Speedway part# 175-0128
    11/16" RH rod end
  8. tlmartin84
    tlmartin84
    from WV
    3/8" male on each end
    Well worst comes to worst, Ill get em at mcmaster, I was just hoping to throw them onto the next speedway order.
  9. tlmartin84
    tlmartin84
    from WV
  10. oj
    oj
    McM has higher quality than speedway...if you pick the right ones. I prefer the bronze insert for steering and general useage. For suspension i get xmoly from elsewhere.
  11. oj
    oj
    Ah, those. they are scarce, i have gotten them from detroit speed suspension people. Where they get them from i have no idea, i try to engineer around useing them.
  12. RichFox
    RichFox
    I get mine from Summit. Cheaper than Speedway. And faster to here.
  13. Speedway won't have them. Probably won't find much of a better deal than McMaster...
  14. jnichols
    jnichols
  15. prewarcars4me
    prewarcars4me
    from Bhc, AZ
  16. tlmartin84
    tlmartin84
    from WV
    That is exactly what I am looking for, they are custom at aurora.... I would think these would be common as they are used on the ends of most rack and pinions???
    Guess I'm gonna have to order through mcmastercarr, I just hate paying the shipping when I order through places like summit, jegs, and speedway on a regular basis.
  17. Curious as to the use of these?
  18. tlmartin84
    tlmartin84
    from WV
    Well they are typically found on rack and pinions. I am wanting one to operate my clutch fork with.
  19. saltflats
    saltflats
    from Missouri
    Can you go to the parts store and find an inner tie rod and modify it to work?
  20. RichFox
    RichFox
    Now I know what you want, Midwest Controls sells them. Could you get a junk R&P and modify the parts from that?
  21. Jpriebe66
    Jpriebe66
    For all the HAMBers, I have discovered that anything I can find at Lefthanders is so much higher quality and much cheaper than anything I buy from the drag race or hot rod outlets. I guess the circle trackers are out there manufacturing this stuff trying to make enough $ to go racing one more weekend. Everything I've bought from their catalog is "Buddy Lee" tough, can't bust it. I also can't believe the prices for the quality. Check them out next time you're building a ch***is. Compare prices and quality, see if you agree.
  22. dirt t
    dirt t
  23. Mr48chev
    I'd just get them from McMaster-Carr I used to order odd pieces from them all the time and they don't give a rip how big or small the order is and don't beat up on you on shipping. Half the small shops that would sell them are going to get them there anyhow and then add their percentage.
  24. O/T I had a older mechanic leave a R&P inner tie rod with me and said, "throw it away or use it as a core plug installer" and I have used it for that purpose and it was great! Cool no-buck tool!
