Rochester 1 barrel experts please help (stuck bb)
Discussion in 'The Hokey Ass Message Board' started by flying53gmc, Oct 17, 2012.
  1. flying53gmc
    flying53gmc
    from M-boro, TN
    I have a carb off a 216 chevy (Rochester B) and there is a bb that serves as a one way valve under the accelerator pump. IT IS STUCK AS HELL. I have tried to use o-ring picks to free it up. I have soaked it. I have taken off the adjacent screen and put an air gun on it with 140psi. I have even put a little heat on it. I can't get it out. Please help.
  2. junior 1957
    junior 1957
    get a grease gun with a needle end on it, push grease up through the pickup hole in the float bowl.
  3. diamond jeff
    diamond jeff
    from montana
    That check ball is aluminum, maybe soak it with some coca cola overnight. Also if your accelerator pump is the type with a check ball in the lower stem the pump well does not need a check ball fill p***age, gas comes over the well through the stem. Hope this helps.
  4. flying53gmc
    flying53gmc
    from M-boro, TN
    I think my accel pump does have a check ball in the lower stem. So what your saying is I can just leave it stuck? That would solve all my problems if that is correct.
  5. diamond jeff
    diamond jeff
    from montana
    That is correct, not all B,BC,BV rochester carbs used a pump well intake p***age. As long as the float level allows fuel to come in over plunger at rest, the pump stem check ball will alow gas to flow to under side of accelerator pump. When pump is depressed check ball will block stem p***age and fuel will be forced past discharge 3/16" steel ball and spring through squirter port.
