If it is the 36 tapered tube driveshaft, the rear coupler is part of the driveshaft. Just 1 pin to remove. Sent from my DROID device using the TJJ mobile app
Hi Coopsdaddy, Am I missing something? What car are you asking about? Are all cars of this era the same? I'd like to know about a 36 Ford. I'm about to take mine apart. Thanks. Bruce
I am trying to get the coupler off my 39 (two pins). Not successful yet even with the peening removed. May have to drill it out(
I finally got it out but I had to grind quite a bit of material off of the peening before I could get the right drift size/position to drive it out. bd
