home made tools and equipment...
Discussion in 'The Hokey Ass Message Board' started by kustombuilder, Jan 16, 2008.
  1. Als27T
    Als27T
  2. Blue One
    Blue One
    from Alberta
    I have one I believe is discontinued. I found a brand new one though.
    http://www.grainger.com/Grainger/DAYTON-Right-Angle-ACDC-Gearmotor-2Z797
    DAYTON AC/DC GEARMOTORE MODEL # 2Z797C
    Volt - 115 AC/DC
    HZ - 50/60
    AMPS - 1.3
    Ratio - 1787:1
    HP - 1/15
    RPM - 2.8 F/L 9.0 N/L
    Torque - 250 In.Lb
  3. cabriolethiboy
    cabriolethiboy
    I used a HF 1/2 "D" handle drill to power mine. $28.00 on sale. It drives a GM power window transmission to get the 90 degrees and for the gear reduction.
  4. rockable
    rockable
    This is absolutely true. The way I did mine, the reinforcement was all mounted on one side of the plate however and I ***umed he was doing the same. Sorry for any confusion.
  5. ago
    ago
    from pgh. pa.
    How about a 12V. windshield wiper motor and an HO train transformer.
    Ago
  6. naughtyboy
    naughtyboy
    from uk
    heres a transfer box adaptor i made to my floor jack allows me to lift it square to gearbox then slide it on.
    you may notice most of my tools are for landrovers.
    even got pic of boss in one, not allowed to do anything without her helping.
    she is actually a fair way from jack just looks like she is next to it.
    also a pic of extension top for drill press from s**** pce of steel chequer plate from a skip, and some modified welding clamps to use with it welds have been cleaned up since pics taken.
  7. bjinatj
    bjinatj
    Not to rain on your parade, but a wiper motor may spin it, but not under load..
  8. hotrod--willys
    hotrod--willys
    This is my buffer that was made for small buffing jobs. Also photo of my planishing hammer.:D
    33essex likes this.
  9. Can you reverse, and control speed?
  10. RICH B
    RICH B
    I saw a similar set up, where a homemade foot pedal operated a bike cable
    which in turn pulled the trigger on the drill for variable speed. There is a video somewhere on you tube that shows it in operation.
    If you wanted to dedicate the drill to the roller, you could probably get inside
    and wire a remote reversing switch. We used to put remote switches on the big 1-1/4" Black and Decker drills we used on our shop made truck frame drills.
  11. jazz1
    jazz1
    I thought it was just me having trouble seeing,,that's a great idea...my wife just came home with the new mini mag light,,it's about an inch longer but much brighter than the old mini mags
  12. Blue One
    Blue One
    from Alberta
    I would use something much cheaper than the actual Mag Light brand flashlights. At most tool stores or building supply places, auto parts stores etc., you can pick up cheap LED flashlights with 7 or more LEDs in them.
    They run on 3 AAA batteries and are shorter than a typical Mag Light.
    And the best part is that sometimes they are less tan $5.
  13. willymakeit
    willymakeit
    Now I like that. Thanks
  14. lawman
    lawman
    That is like sooooo neat !!!!! Great work !!!!
  15. 296 V8
    296 V8
    from Nor~Cal
    X2 .... very cool ideas there
  16. How does that wiper transmission hold up ?
    My bead roller has some huge motors and gear boxes on it.
    It will roll 11gauge too.
    Treadmill motors are great for stuff.
  17. hillbilly4008
    hillbilly4008
    from Rome NY
    OK, you guys really need to stop quoting all the pictures...
  18. cabriolethiboy
    cabriolethiboy
    Yes for both.
  19. cabriolethiboy
    cabriolethiboy
    It has held up so far. Like I said if I had to do it again I would do different. But if it doesn't break, I won't fix it.
  20. 64Cyclone
    64Cyclone
    I bought a Woodward bead roller because I read the body was thicker than the HF roller. It may be, but it even flexes bad when rolling 22g sheet metal. Time for some reinforcing.
    Now of course these rollers just come with a few sets of dies and the bead rollers aren't meant to do designs really (I guess you could replacing the bottom die with a skateboard wheel) but I was playing around to see what kind of radiuses I could get and this was the first piece I tried on. 22g steel.
    Now I need to get this thing stronger and make some patch panels.
  21. 22george
    22george
    from ohio
    this is one of those that is so simple and looks so effective that it makes you wonder why didn't l think of it
  22. Patdoody
    Patdoody
  23. Patdoody
    Patdoody
  24. Oh I agree, I have no idea which of the several hundred examples you speak of but I agree.
  25. 64Cyclone
    64Cyclone
    I posted this in the "wanted" section if anyone interested in giving it a shot.
    I was wondering if anyone would be interested in making me an adapter sleeve for mount a Grant style wheel to a Chinese (HF/Woodward) bead roller.
    It would have to a sleeve with a set screw and an stg wheel adapter plate welded on the end.
    It should be pretty simple but I don't have the equiptment.
    I really don't want to ruin the crank handle in case I want to use it later.
    There may be a small market here for these adapters since many own these econo. rollers.
  26. sir
    sir
    lift table made from a front end lift...
      526.1 KB
  27. Ricci32
    Ricci32
    My newly fabricated buffing station one 3650 rpm motor and one 1750 arbor driven buffer all parts were laying aroud the shop even the stand
  28. Blue One
    Blue One
    from Alberta
    That one picture is just messed up. I don't know why you would not fix it before posting.
  29. 64Cyclone
    64Cyclone
    Found out a member here makes an adapter for the HF model. I just have to verify my Woodward's shafts are the same size as the HF.
  30. porsche930dude
    porsche930dude
    My Ramps. Great for low cars and free to build
