Hot Rods 303 Olds OR 331 Caddy ???
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Sep 30, 2012.
  1. woodbutcher
    woodbutcher
    :) Hi HC.Know what you mean about the bankroll.Its like what the Missus said the other day"We`re so poor that we can`t even pay attention".
    Good luck.Have fun.Be safe.
    Leo
  2. harleycontracter
    harleycontracter
    Going with a 331 Caddy Looking for something different . And I found a good deal on a Caddy. Thanks for all the comments once again !!
  3. PackardV8
    PackardV8
    Why go with common stuff like Olds/Cad when you could have a '55-56 Packard V8? The best are the '56 374", but even a 320" or 352" will run heads up and have a cool factor which can't be beat. Here's one in Carl Schmidli's roadster.
    jack vines
  4. falconsprint63
    falconsprint63
    from Mayberry
    raddycack all the way
  5. GARY T.
    GARY T.
    from S.W. Pa
    On the Caddy,no need for adj pushrods or adj rockers UNLESS you have solid lifters OR a reground camshaft
  6. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    I'm a Caddy guy, but you really can't go wrong either way. If there are any specific speed parts you're looking for either way send me a PM.
  7. boo
    boo
    from stuart,fl.
    2002 bought a 1955 331 cad eng w/48000 orig miles on ebay $500.01. found 3x2 intake 2005, flywheel 2003, trans adapt at LA rdst sho 2008, t-85 od trans 2010, 3 stromberg carbs last week, new valy and valv cvrs 2010. 34 rdst working on it now, sometimes takes a while to find the parts you want. start looking while you are young.
  8. PackardV8
    PackardV8
    Not arguing with the Olds/Cad expert, but the GM figures are:
    1955 331" Cad - Maximum Torque 345 Lbs.Ft. @ RPM @ 2800 RPM
    1955 324" Olds - Maximum Torque 340 Lbs.Ft. @ RPM:mad: 2400 RPM
    So it appears in stock trim they make almost the same torque, but the Olds does it at 400 RPMs lower.
    What else makes the Olds make more power easier?
    jack vines
  9. GOATROPER02
    GOATROPER02
    from OHIO
  10. Hdonlybob
    Hdonlybob
    You don't build one of these every day, (or most of us don't) an it is not going to be cheap, so cost on the engines should not be a factor..
    Both engines are cool, but this Ol" 68 year old votes Caddy all the way...
    Good luck, and keep us in the loop.
    Cheers......
  11. Bert Kollar
    Bert Kollar
    Back in the day our club had four Olds powered coupes and one Cad We liked the Olds best
  12. harleycontracter
    harleycontracter
    Picked up a 54 331 Caddy yesterday.............................
  13. congrats.
    Here the 331 That I put in my 34. Don't even think I am gonna paint it.
  14. F&J
    F&J
    ^ I wonder if that p***enger side exhaust flange will clear the 32 firewall?
    I was talking with your engine builder today, and I thought he said your manifolds were center dumps??
    Edit; if your manifold looks like that, I wonder if you could use 2 left side manifolds, if the lefts are center dump.
  15. ^^^ the manifold didn't clear my 34 firewall. Solution is to get a drivers side and place on p*** side. The collector is pointing the wrong way, but that gives you more room to get the exhaust around the starter.
    Those above are 1950 manifolds, later years may be different.
  16. harleycontracter
    harleycontracter
    Frank, Pretty sure they are center dumps. Only had the engine for 30 mins before Dave got it lol
  17. ol fueler
    ol fueler
    I guess I am partial , but I would go with an OLDS. Ran a few years back , never blew one up , Can't say that for any other motor I had, from Flattys to Hemis-- 'nother thing I love about them is their sound -- got a real distintive exhaust note -- you can tell it's an Olds a mile away!
  18. Torkwrench
    Torkwrench
    Cool. :cool::cool::cool::cool:
    I'll be following your build, since I'm putting a 54 331 in my 34 Chevy. Hope to start on the engine sometime next spring/early summer.
  19. harleycontracter
    harleycontracter
    Dropped my motor off to Dave50 yesterday to see what I really have inside it
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    you will be happy with the cad. my 49 331 runs great in my 40 ford
    kidcampbell71 likes this.
  21. Dave50
    Dave50
    Thats one beautiful car! Very nice
  22. harleycontracter
    harleycontracter
    Great lookin car AND motor
  23. Hank37
    Hank37
    I had an Olds. in my 37 before I switched to a Caddy. The Olds was a lot heavier and bigger than the Caddy. I had alot more room under the hood and the car handled better and was faster.
  24. PackardV8
    PackardV8
    Beautimous! What is that intake on the Cad? So much bling I couldn't make out what was under there.
    jack vines
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    it is a horne intake, pretty rare
  26. I like the throttle linkage arm,very simple.
  27. wastedchilhood
    wastedchilhood
    Olds is the cheapest to rebuild, 49-56 engine, ,Pontiac rod bearings Chev. lifters,late Olds timing chain. Lots of nos .super wild cams around buy one and it reground for street use,
  28. oldsjoe
    oldsjoe
    I always lean toward the Olds! But I am somewhat biased!
  29. Dave50
    Dave50
    cheap like a chevy :p:p:D:D
  30. TexasSpeed
    TexasSpeed
    from Texas
    I would love to run a Caddy one day but I also want an Olds. It doesn't help that I know where a running Caddy 331 is in town that might be for sale..
