1950 Ford vent window glass
Discussion in 'The Hokey Ass Message Board' started by albjerryg, Oct 20, 2012.
  1. albjerryg
    albjerryg
    Any hints or clues on how to remove the gl*** from the Drivers side vent window hardware? Thanks Jerry
  2. HOTRODPRIMER
    HOTRODPRIMER
    Take the frame or car to a gl*** shop,,they have specialty pliers that grab the gl*** and pushes against the frame.
    The only other way I know of removing the gl*** is a hammer,,:rolleyes: HRP
  3. albjerryg
    albjerryg
    Thanks for the input , I was wandering if using a heat gun would loose it up? thanks Jerry
  4. 62rebel
    62rebel
    if you've got the ***embly out on the bench, you can usually put it horizontal and let some WD40 or PBlaster soak the rubber gasket for a while, then pull on the free end of the gl*** by hand and it will slide out. i've swapped vent gl*** on Galaxie hardtop vent windows this way to get tinted gl*** where the car came with plain. you have to really clean the ***embly up with thinner to get the WD40 off and make the rubber sticky enough to hold the new gl*** in. if it's still on the car, you might slowly trickle some WD40 into the gap between the gl*** and rubber. i'm surprised at how little effort it actually takes to pull that gl*** out....
  5. gtnrkix
    gtnrkix
    I agree with 62rebel. I changed mine on my chopped 50, WD40 and a little patience will loosen them right up.
  6. albjerryg
    albjerryg
    Yes I do have the gl*** out and I will try the WD40 and see what happens. I have to change the pivot out it is broken, and the gl*** has glue runs all over it. Thanks Again for the advice....Jerry
  7. HOTRODPRIMER
    HOTRODPRIMER
    I kept hearing everyone saying how easy it was to remove the gl*** from the frame using WD 40,,It didn't work for me. HRP
  8. john worden
    john worden
    from iowa
    I've laid a block of hardwood flat on the gl*** and against the frame. Rap on the wood block pushing the frame away from the gl***. Move the block to different locations and both sides of the gl*** and repeat. They can be difficult and beware that the frame can be bent. I 've never used lube but sounds like it helps and I think warming the piece couldn't hurt either. luck
  9. 62rebel
    62rebel
    that's worked for me in the past as well as gently prying on the free edge of the gl*** with a small screwdriver. i was trying to save the broken Galaxie vent for the gl*** shop to use as a pattern when i did that.
  10. sgvogle
    sgvogle
    I noticed the chop on your truck. Would you mind telling me how many inches specifically that you chopped it. I have a 51 F1 that we're preparing to chop by 2.75", but you're appears to be more than that, and I really like it. Thanks.
    Greg
