Powercoating leaves of a spring?
Discussion in 'The Hokey Ass Message Board' started by deucetruck, Oct 22, 2012.
  1. deucetruck
    deucetruck
    from Missouri
    When powdercoating the individual leaves of a spring stack, is there a risk of over-heating the springs and causing harm/weakness to them? What is the hottest temp you should heat the spring when coating? Or is this something to steer clear of?
    Let's hear your opinions. Thanks.
  2. Go ahead and powder coat them, the 400 degrees F or so will not effect the temper. I am curious about how long the epoxy will last with the leaf against leaf rubbing? Will it wear a pocket and bind up ?
  3. I powder a bunch of em, and nope the temp doesn't affect them. I bake at 375
  4. Midget25
    Midget25
    Does the coating stay on?
  5. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yes, mine is powder coated and it doesn't crack off like you might think.
    Don
  6. treb11
    treb11
    powder coating is basicly plastic and does have some flexibility. you could probably tailor the powder mix to be more flexible. it will wear at the contact points, but since it is bonded to the surface, it wont flake as much as paint. its safer for springs than chrome plating because there's no risk of hydrogen embrittlement.
  7. 390Merc
    390Merc
    from Indiana
    I had the 6-leaf per side leaf springs of my 64 Galaxie coated several years ago and they still look great! I used a thin rubber strip in between the clamps though to prevent chipping.
  8. deucetruck
    deucetruck
    from Missouri
    Thanks for your posts.
  9. 400 degrees will not hurt your spring in the slightest and that is what powder coat should be cured at.
    I think it would actually make for a smoother ride because powder coat is slippery.
  10. tlmartin84
    tlmartin84
    from WV
    I am using leaf liners on mine, but I went with an epoxy (KBS) coating on mine. (Just in case you are worried about the rubbing)
    http://www.speedwaymotors.com/search-leaf-spring-liner.html
    I used some plastic bags masking some stuff off. When the KBS dried I peeled it off of the plastic and it looks like a piece of powder coat that has peeled.
  11. black 62
    black 62
    from arkansas
    use the teflon ****ons at the rub points and you will be fine---can also be found in sheet and strip form
  12. Chris
    Chris
    I even reversed the eyes on a powder coated main leaf and it did not hurt thew coating!!!
  13. Unkl Ian
    Unkl Ian
    Anything under 500F is no problem for the spring.
  14. deucetruck
    deucetruck
    from Missouri
    Thanks again for all of the input. Wanted to hear from some with more building experience than me (which is just about everybody here.....HA!)
