some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. cornfieldcustoms
    cornfieldcustoms
    thanks guys
    this weekend i helped a buddy make a new pulley guard for his 61 wheel horse 701 lawn tractor
    here is what we started with
    started to make the new one by taking some 18 guage sheet metal and bending a 90* flange on one side. then i took a radiused T dolly and ******* and made the crisp 90 into a radiused 90 to match the original. then took took it to the shrinker and used it shape the side to match the original.
    hammering out some tucks that formed
    back to more shrinking
    all the shrinking and hammering done to match and tacked together
    then moved on to the top section. made a cardboard template and transferred it to steel. here it is with the bead rolled into it and cutting it to fit the side
    all trimmed and tacked in place
    all welded up and ground down. still needs some hammer and dolly work and filing to smooth it out
    all finished up being help in place for a test fit
    and what it covers up
  2. Country Gent
    Country Gent
    From a old fart to a metal artist, this thread has been amazing. When I come back in my second life, I want to be you. Just curious, how, when, and where did you learn this trade, besides being gifted. I did notice that this thread started months ago, and if you are not on your way to being famous, you will be. hell, you made it there in my book. Best to Ya Mike. PS- do you ever sleep???
  3. cornfieldcustoms
    cornfieldcustoms
    thanks for the kind words. believe it or not i am self taught for the most part. what i have picked up on from watching videos and ready articles, i have just tried and worked on getting better. i still have a long way to go, i am still pretty young. i actually sleep a lot lol i have a sleep disorder lol. these are just some of the little things i work on and post between the normal day to day work at the shop on not post worthy projects. thanks again for the kind words
  4. Drivinford
    Drivinford
    Awsome work man.
  5. cornfieldcustoms
    cornfieldcustoms
    made a little progress on this one today. the original quarters had the fenders gas welded on, higher than normal. needless to say they did a horrible job and ruined the quarters. i tried to grind down the welds and straighten the original metal, but it was to thin and brittle. so i decided to just make new centers for the quarters. here is how they are coming out
    before i got started
    the old quarter center removed
    the new sheet metal, spent some time on the english wheel to get the crown to match the original.
    first test fit, pulled it back off and did some more wheeling and shrinking on the flanged side
    started tacking it in place
    mostly welded up and ground, ran out of welding wire for the day. once i get it fully welded and ground, i will do some more metal working to finish it out
    since i ran out of welding wire and had a couple more hours till close, i started on the hood. making a cardboard template
    bead rolled, flange bent, and ran through the slip roll
    some more rolling
    got it fitting good, still needs some finish work
  6. c_dime81
    c_dime81
    from tupelo
    Great looking metal craftsmanship.
  7. toolman1967
    toolman1967
    Very nice work, great to see it posted.
    Tim the Toolman
  8. gatz
    gatz
    great work !
    you have an enviable skill that will serve you well.
  9. cornfieldcustoms
    cornfieldcustoms
    got the driver quarter pretty much finished ( still need to do a little the rear area) .after all the welding and grinding i think it turned out nice, will just need a little filler right around the body lines to smooth out some of the grinding marks. then it was time to start on the wheel well.
    cut the old wheel well out
    the customer had already bought these wheel wells so i will use them. needed to be cut out for axle and spring clearance. i also moved the finished ends of the beads up that i had to cut through. i think it gives it a nice finished look.
    then i need to add the flange back on where i cut
    -Brent- likes this.
  10. dragsled
    dragsled
    from Panama IA
    Mike you guys work is beautiful, I'm very proud to say my dragster ch***is came outa that shop, Tim Jones
  11. wow thats some beautiful work!!! I dig what you did on the rear quarters!!!
  12. cornfieldcustoms
    cornfieldcustoms
    got the wheel wells tacked in and then welded solid and smoothed out
    -Brent- and kiwijeff like this.
  13. mdapperdan
    mdapperdan
    from Az.
    Craftmenship is always great to see.
  14. oldrodder43
    oldrodder43
    Lord you are a very talented and crafty person. Wish you lived closer, I'd be in your shop all the time. With your permission of course! perley
  15. Midwest Rodder
    Midwest Rodder
    Damn man, very high quality work!
  16. cornfieldcustoms
    cornfieldcustoms
    knocked out a patch panel for a customer, for his 30-31 model a door. the shadow in the first pic makes the panel look funny so i took two
  17. A Rodder
    A Rodder
    Damn, you're good!
  18. motoandy
    motoandy
    from MB, SC
    damn fine work. Thanks for sharing your skills
  19. HotRodHighley
    HotRodHighley
    from cincy, oh
    Looks good Mike. I'll see you tomorrow.
    Thanks
  20. cornfieldcustoms
    cornfieldcustoms
    this isnt really a hamb style build but is kind of hot rod based and is in the year guidelines, so i figured i would post it anyways
    since i am finally back on track and back into my normal rotation of work. got the front end mocked up, and the new rear had a bunch of ugly **** all over so i got it all cleaned up and ready for the new 4 link. just waiting on some parts to come in on the rear.
    front end
    the rear end before cleaning it up
    all cleaned up
    the short block showed up today as well
    and a side shot set up at ride height
  21. cornfieldcustoms
    cornfieldcustoms
    finishing up a 1930 roadster for my uncle. he bought this form one of my customers that had lost interest in it. i did not build the car to this point, but will be finishing it. needs a little more metal work and ch***is welding, then body, paint, and interior. hope to have it finished for him in march.
    as it came in, mostly mocked up
    some of the work that needs to be finished up.
    the start of the new distributor recess in the firewall
    after some shrinking, plannishing, and rolling. also got the head recess made for the p***enger side and welded in
    pulled the motor and trans to aid in finishing the firewall work
  22. lawman
    lawman
    Nice work !!!!!
  23. impala631
    impala631
    from INDIANA
    Good stuff,keep the pics coming
  24. 64Cyclone
    64Cyclone
    Man you've got skills. Very nice.
  25. NickJT
    NickJT
    from S.E. PA
    Congratulations on such excellent craftsmanship and fabrication skills.
  26. cornfieldcustoms
    cornfieldcustoms
    thanks for the compliments guys
    made a little more progress on this one for the week. i will try to get a little more done on this one before i switch to another car next week. finished up the firewall, and got the seat and other stuff out to get ready for more metal work
    finished off the bottom of the distributor recess in the firewall, with a flange to meets up to the original flange for the floor. it looks funny in the first pic, my guess is from the flash
    had to make a support bracket for the brake pedal and master cylinder
    some welds on the bracket
    installed
    going to make some panels to separate the trunk compartment from the p***enger compartment, it will also aid in attaching the upholstery
  27. cornfieldcustoms
    cornfieldcustoms
    so i had a customer drop this car of that he bought. it was half *** tacked together and needed to be redone as well as some other work he is wanting done.
    brookville frame that has had the rear x member cut off. going to "Z" it 3 inches in the rear
    trimmed and rounded the rear section at the point of the new "Z"
    the frame "Z"ed and the sub rails laid on the frame
    cutting and re working the subframe
    starting to get the sheet metal clamped onto the subframe. then all the bracing
    angled the rear sub rail back down to get the body to sit level
  28. cornfieldcustoms
    cornfieldcustoms
    the other day i got a package that had a sketch of some lower cowl patch panels for a 37 ford truck, and also one windshield wiper motor cover. i needed to make two lower patches and both motor covers. so here is what i did
    here was the wiper motor cover he sent me.
    after a trip through the slip roll
    and a little wheeling to get it closer to a good match
    after some more wheeling, and running it through the bead roller to get the flange
    now time for the lower body patch. i didnt have a bead the right size and shape so i had to hand make it
    ran it through the bead roller to get the bead started with a step
    after some hammering on a 1 in round T dolly
    all finished up after a lot more hammering and plannishing and repeating the processes for the opposite side panel
  29. Drivinford
    Drivinford
    Great idea. Thanks for sharing
  30. ctc34
    ctc34
    Nice work! Do you incorporate tig welding into some of your work also?
