Projects Flat FED build
Discussion in 'Traditional Hot Rods' started by roseville carl, Jan 14, 2010.
  1. Goose
    Goose
    I have the birthday party on Saturday at Chucky Cheese lol! I will stay in touch. I don't get to see my little buddy as much as I would like so I try to spend as much time with him as possible.
  2. roseville carl
    roseville carl
    Goose.......Heck bring him with ya ..........
    Now at least when you are waiting for parts you can move on to other things in the back of your mind......
    Burst plate for the 4-71, take one chunk of aluminum and remove everything that doesn't look like a burst plate, drill n tap 18 damn holes, hog out the rest........
    and wa la you have something that looks like it will work, just glad I don't have to pay by the hour, this would some expensive ****.......
  3. dragsled
    dragsled
    from Panama IA
    Looks good Carl , and of course you always get to say, Yeah I buildt that too,:D Making stuff yourself always beats the **** outa buying it;) Tim Jones
  4. fenderless
    fenderless
    from Norway
    Looking good Carl:) I'm a spy at the moment, intake-spy:D!
    Kjell
    Taildragger&fenderless
  5. Goose
    Goose
    I might just do that Carl. I will wait see what he wants to do. That looks like a lot of work Carl!! I found some Holley 2110 carbs that we might try on flatty. The are 1 5/32 inch bores which is a lot bigger than the 94s we are presently running. Will have to do some work on the intake in order to take advantage of the bigger carbs. We are also thinking blower maybe. The 2110's look just like the 94s only bigger by about 3/16 of an inch. Take a break for a little while Carl and have a cold one!!
  6. I used to run three of those 2110 carbs on one of my big race flatheads - ran really well and are a much more modern improvement to the Stromberg design. I also ran two of them on a blown flathead (SCoT blower) that was a race-only engine - ran well on that setup.
    Lots of parts available as Holley used essentially the same carb (except for a 4-bolt base) on what was known as the 'Bug Spray' carbs for VWs in the 70's.
    I've got a good stash of them - for future projects! :rolleyes:
  7. Goose
    Goose
    They just look a lot bigger than the 94s which they are which has to be a big advantage. More fuel and air means more HP!!
  8. Goose
    Goose
    Makes me look forward to next year when we get to run the rail again with those carbs on it. We have 3 94s on it right now with 68 jets in them it and it still seems to want more fuel!
  9. roseville carl
    roseville carl
    then you need 4 94's
  10. Goose
    Goose
    Going to try the 2110's for now since we don't have a 4 deuce manifold. Got 2 rebuilt and ordered a longer throttle shaft tonight for the last one.
  11. roseville carl
    roseville carl
    Well I got the blower plenum tacked together today, think I'm gonna call this manifold the "pig trough".........
    now to spend a day welding this ****er up...........
  12. Goose
    Goose
    Very cool Carl!
  13. dragsled
    dragsled
    from Panama IA
    Ha Ha Pig Trough, Great name sounds like something from Panama IA:D That reminds me I need to clean up my learning how to tig weld Alum ,Bird**** welds on mine:eek: Tim Jones
  14. roseville carl
    roseville carl
    just keep practiceing Tim, course when you have the shakes like me it doesn't help, I have to try to heep the puddle straight while shaking its tough...........
  15. coupemerc
    coupemerc
    Manifold looks cool. The burst panels we used to run would fatigue and fail from cycling on and off boost. We used to tap the web behind the burst panel for a small ****on head screw and lock nut. The head of the screw would snub and minimize oil canning of the burst panel. Keep up the good work.
  16. roseville carl
    roseville carl
    coupemerc, thanks for the advice I will do that to the burst panel...
    well it looks cool ......even if it ain't done......
    now to get busy on fabbin up the drive and pulleys ect........
    j-jock likes this.
  17. straightaxle65
    straightaxle65
    Not to Hyjack the thread here but were do you find the 2110s? What applications were they used on?
  18. roseville carl
    roseville carl
    2110's were used on 55 Ford mercs and 56-57 Ford trucks plus a lot of other trucks......
  19. roseville carl
    roseville carl
    well another day another problem to fix, got the parts in for the trans.....
    tore it apart......
    found one of many problems.......flattie making some hp I guess.....
    will take about .005 off the drum to clean it up, then will have some racing parts to put back in her!!!!
    And the beat goes on, and on , and on.........
  20. Vergil
    Vergil
    I like your updates Carl ... thanks ...
  21. Model A Mark
    Model A Mark
    from dallas
    hey carl, what are you setting that rear band clearence at ?
    do you have a manual shift kit in the vb ?
  22. roseville carl
    roseville carl
    1 1/2 turns and yes a manual shift
    of course now I added a servo kit....
  23. Model A Mark
    Model A Mark
    from dallas
    hey Carl, that rear band is manual low and reverse, it has to let completely go when the unit shifts into second, I always set my rear band to 3 turns out, built a million c4s.
    could be your burnt band condition could be from dragging it in second ?
    just my 2cents.
    I love your thread, iv been watching you since you started this.
    lots of luck to you.
    mark...
  24. roseville carl
    roseville carl
    Thanks Mark will keep that in mind when re settin this up.........
  25. Model A Mark
    Model A Mark
    from dallas
    anytime carl, wish i could be more help..
  26. roseville carl
    roseville carl
    Well got the drum cleaned up but they sent me the wrong bushings for the input shaft......have to wait for more parts........
    and the beat goes on, and on and on and on..........
    maybe tomorrow I will go get the material for the blower drive and get started on that..........
    j-jock likes this.
  27. 64 DODGE 440
    64 DODGE 440
    from so cal
    Wow Carl. Nice tool post grinder. You should post that on the Homemade Tools and Equipment thread.
  28. roseville carl
    roseville carl
    Thanks Tom I think I did at some point just got through with this tool too
  29. Goose
    Goose
    Hey Carl,
    Here is the intake manifold as it is being fly cut to match the size of the 2110 Holleys.
  30. Old6rodder
    Old6rodder
    from SoCal
    Methinks this ain't the first time you've resorted to this cobble, Sir ....... :D
