photo posting revisted
Discussion in 'Questions & Suggestions' started by 59FORD, Nov 11, 2003.
  1. AngleDrive
    AngleDrive
    from Florida
    test2
  2. AngleDrive
    AngleDrive
    from Florida
    test
  3. A Boner
    A Boner
  4. Meyer
    Meyer
  5. kiwiandy
    kiwiandy
  6. seaqueen
    seaqueen
    from australia
    Just for testing.
  7. hjgarage
    hjgarage
    from Sweden
    Only testing this.
    Original picture was very large as 4000somethingx3000something pixels.
    on photobucket I copied the url for clickable thumbnail
    here I copied the image code and tried to alter the size here on this forum, but I suppose the forum does not support BB resize code, or am I doing something wrong?
    [IMG=100x100]http://i1257.photobucket.com/albums/ii517/hjgarage/8c2361d8.jpg[/IMG]
    here I tried to alter the size of the thumbnail, does not work
    [IMG=100x100][​IMG][/IMG]
    I finally changed the size of the picture on phobuckets own editing program. It works fine but if you have a slow internet connection as I do. It is much faster to edit the before you upload the pictures. This picture is resized to 640x480.
    I suppose the easiest way is to set the camera to take small, low resolution pictures, but then you might loose the benefits with large pictures losing the details you might want.
  8. Lowrie
    Lowrie
  9. You've got the right idea about downsizing your pics before uploading them. 640 x 480 or 800 x 600 is plenty big to post in the forums. And if you compress your jpegs a little bit you can make the file sizes considerably smaller with very little loss of quality. And it's pretty quick and easy to resize a batch of photos with free software like Irfanview or Picasa.
    You can set your camera to take smaller images but I wouldn't generally recommend it unless you're sure you only need them for web display. If you want to make prints you'll need the bigger, higher resolution images.
    If you need detail in a smaller pic try to get in closer to your subject. Try the "Macro" setting on your camera. I think a lot of people forget it's there or how it works.
  10. 296 V8
    296 V8
    from Nor~Cal
    small video test
  11. A Boner
    A Boner
  12. A Boner
    A Boner
  13. Total Distortion
    Total Distortion
  14. don daddyo
    don daddyo
  15. don daddyo
    don daddyo
  16. fleet-master
    fleet-master
  17. fleet-master
    fleet-master
  18. VintageWireWorks
    VintageWireWorks
    Not an Autoette. It's a Motorette made in Buffalo, NY probably a 1946 or 47 model.
  19. Spooky Two
    Spooky Two
  20. Spooky Two
    Spooky Two
  21. Spooky Two
    Spooky Two
  22. unolf
    unolf
    Test....
  23. nosdan
    nosdan
  24. 30 A coupe
    30 A coupe
    Test
  25. 30 A coupe
    30 A coupe
    Test[​IMG]
  26. 30 A coupe
    30 A coupe
    Test
  27. 30 A coupe
    30 A coupe
  28. 30 A coupe
    30 A coupe
    http://Foto URL voor gebruik op andere websites: [url]http://images62.fotki.com/v1453/photos/5/1067625/8700305/58405104938719-vi.jpg[/url]
  29. 30 A coupe
    30 A coupe
