Pickups with dropped axles
Discussion in 'The Hokey Ass Message Board' started by 55 Mercury, Feb 1, 2011.
  1. BLUMEANIE
    BLUMEANIE
    from St. Louis
    I've got one of your 4" axles, Sid. I'll post pics once I get it in at some point this summer.
  2. 55 Mercury
    55 Mercury
    Here is a 1960 Ford pickup that I just got done dropping. It has one of my 3" dropped axles and a Posie Dual-flex spring up front. The rear end has the front rear spring hangers flipped and moved to top of frame. I reversed the eyes on the main leaf. The rear end is still under the spring.
    www.droppedaxles.com
  3. redroaddog
    redroaddog
    wow like ur truck hadn't seen it before grille looks right at home very cool!:D
  4. 55 Mercury
    55 Mercury
  5. We run a 3" drop axle from CPP with Durant mono springs.
    Not a problem.
  6. Rich Wright
    Rich Wright
    3"axle from SIDS and mono leaf springs. I don't have any bump steer but the ride is indeed harsh.. In fact, it rides like **** over even the mildest of uneven roads.
    I'm thinking of going back to stock springs with a couple of leaves removed. I'd like to try Posies 3" springs but I'm not sure it'll actually drop the front end down to where it is now.
    I have a flipped axle with Posies springs in the rear and like them, though, so I might bite the bullet and get a set for the front. I can always remove a leaf from them...
  7. 55 Mercury
    55 Mercury
    We've used the 3" axle and Posie dual-flex springs on a few AD trucks now. They ride really good. You may need to bend the steering arm on the left side for the drag link when using the Posie dual-flex. The drag link needs to be as level and parralel as posible to the frame so you don't have bump steer
  8. Mr48chev
    That's the perfect stance for an AD truck Rich. Great looking truck too. I may have to save that photo for my "here is how they should sit" file
    Well that bright ***ed idea didn't work like I thought it would but it does show me somewhat what an AD truck will look like chopped, sectioned and stretched in the cab.
    Thanks Rich.
  9. 100% Matt
    100% Matt
    Sids 2.5" drop axle with mono leafs with reversed eyes. Gonna swap the mono's out with Posie twin springs over the winter
      172.6 KB
  10. earlymopar
    earlymopar
    Some great looking trucks guys.
    Sid, I had visited your site for the first time about a month ago after I bought my 65 Dodge Utiline (short narrow bed). When I saw the difference between the early D-100 axle and the 68-71, it looked like an easy (but small) drop would be to simply use a later d-100 axle on an early truck. Is that doable and if so, does it gain anything?
    Thanks,
    - EM
  11. Grumpy
    Grumpy
    from NE Ohio
    Here's my old 60 F100
    Sids 3" drop axle
    With drops
    Main eye reversed and
    3 leaves removed...
    Looked great...Rode terrible.
    So added 2 leafs back which helped some.
    New L78s on rear, G78s front
    volvobrynk likes this.
  12. waldo53
    waldo53
    from ID
    I'm running one of Sid's 3" axles on mine, I also first tried it with mono-leafs but the ride was just......well....jarring! I went back to the stock spring pack with 3 leafs removed, poly liner in between the leafs. The mono's were a little lower but just not worth it for me.
    charleyw, volvobrynk and Hotrodmyk like this.
  13. visor
    visor
    from Missouri
    '56 with 4'' Mor-drop.
  14. gassersteve
    gassersteve
    I will be posting pictures after i get an axle from Sid. Besides i need to pay him for his customer service answering all my first timer questions.
  15. Chris
    Chris
    My old 46 pickup (I want another one!!)
    My 33 pickup
    Both have original Ford axles that have been dropped.
    volvobrynk, BradinNC and Hotrodmyk like this.
  16. cartman4gc
    cartman4gc
    My '47
  17. Red Ryder
    Red Ryder
    Looks good Terd! I may have to do something similar.
  18. cjmac
    cjmac
    Both were Sid's 3 inch drops. Had a local ace install. Both drove and stopped straight. Chalupa had a mono leaf ( rode hard ), removed a leaf or two from the 59 ( rode well )
  19. HIDDEN
    HIDDEN
    3" axle from Sid's w/ the tierod drops and 2 leafs pulled. Rear is dearched with axle still under springs.
  20. APACHE FS
    APACHE FS
    ImageUploadedByTJJ1351459045.287702.jpg ImageUploadedByTJJ1351459104.801768.jpg
    4" axle by Sid and rear flip to level.
  21. 55 Mercury
    55 Mercury
    Here is my latest project. 1960 Ford big back window. It has in the front one of my 3" dropped axles and a new set of Posie Dual-Flex springs. The rear has the front rear spring mounts flipped and moved to the top of the frame. The main leaf springs have reversed eyes and the overload springs removed. I'll post better pics when I get it out of the shop and driving. I'm sure the front springs will settle a little after I drive it.
  22. 4rod
    4rod
    [​IMG]I had a 3inch drop axel with reverse mono and center bolt placement moved forward to center wheel in fender...the rear had stock mono with extended Y hangers and moved front of rear leaf hanger to top of the frame rail. Tires I ran fronts 205 65R15 rear 245 70R 15
  23. kidzintha34fodor
    kidzintha34fodor
    Here is a 49 F-1 that I had earlier this year, Speedway axle with de-arched springs front and rear.
  24. Used Up Junk
    Used Up Junk
    from Merced, CA
    Mine on a 3" Sid's dropped axle and reverse eye Mono leafs.
  25. Sprout
    Sprout
  26. snopeks garage
    snopeks garage
    from macomb MI
    Front is 4in drop axle with flipped leafs and 3 removed. Rear is flipped leafs with 4 removed and raised hangers.
    55 Mercury likes this.
  27. snopeks garage
    snopeks garage
    from macomb MI
    Fronts 4 inch drop axle with flipped leafs 2 removed and main leaf is reverse eyed with spring bolt hole moved 1.25 inches forward. Rear is mid fiftys 5 inch drop leaf kit with the leafs flipped. Yes i like my trucks low ha
    D-Russ and 55 Mercury like this.
  28. snopeks garage
    snopeks garage
    from macomb MI
    Also both trucks have 2 inch tie rod drop blocks and i had to heat and bend the steering arms. i also had to make a new oil pan to clear the axles
  29. 55 Mercury
    55 Mercury
  30. snopeks garage
    snopeks garage
    from macomb MI
    i get all my axles from sid www.droppedaxles.com
    guthriesmith likes this.
