Hi, Is there anyway to repair this tear: Do the upholstery folks use some industry product or do they just replace the panels? If so, how much does it usually run? Thanks!
Generally, if you can't get the edges to touch or come VERY close (like, less than an 1/8th inch) it needs to be re-upholstered.
You could ask these guys. When I work at a Cadillac dealership we had some local guys that did leather repair . It all depends on the overall condition of the leather. <iframe src="http://www.youtube.com/embed/UYVHIqBFkmg?list=UUu4-MTmCa3UZrI7oHHuwSvg&hl=en_US" allowfullscreen="" width="560" frameborder="0" height="315"></iframe>
Pull the cover off Then paint the foam black to hide any flaws in the repair. Then use some contact glue and patch it from the inside with another piece of leather [ rough sides face-to-face ] Duct tape the rip together and clamp it between 2 flat surfaces. Sew back along the s***ch line [ right through the patch underneath ] Note: I have done similar patches using "Cotton Canvas" with success also. Dont use synthetics because it doesn't hold with contact glue [ ADOS F2 ] Be patient and let the glue cure. When you think it is OK walk away from it for 24 hours
I'm willing to bet anyone that does upholstery work on used cars isn't making the repair to last forever, rather than to get the car sold
Yeah, I like the lived in look, too. I just want the cracks fixed since the seat has sentimental value.
If it came to me I'd be recommending the replacement of the panel. That involves Removeing seat cover, (which generally will require taking the seat out ) repair foam, replace the damaged panels and refit. Anything else would be band- aid solution. I'd take 2 hours minimum.
