drill bits are there any good ones!!
Discussion in 'The Hokey Ass Message Board' started by ChefMike, Oct 28, 2012.
  1. deeddude
    deeddude
    I've had good luck with the older "do it best" bits that ace hardware sales. I haven’t been in a while, but these worked in an industrial setting very well. I would always pick up a hand full of the smaller ones when I would go by. I'm pretty good at breaking the 1/8" and smaller using a hand drill; no fault of the bits just me being careless.
  2. I got a grab bag of bits from HF once. No index or size congruence, just a hand full of various size bits. They were all Japanese made (just marked Japan), super high quality bits. All used but resharpened. At HF junk prices too.
    Those are some of the best bits I've ever seen.
    The flutes spiral around the length of the bit several times more than any other bit I have.
    Don't know the technical term for that.
  3. I have a cheapo drill index no doubt chinese, lookes a lot like a fishing tackle box. When the hole saws were a joke the deill bits are excellent.
    That said when I was Working I preferred Chicago Tool drill bits. I also used to hate a machinist who crowded a bit or a tool. I actually had a guy who thought that production meant to run everything faster than was prudent and to lean on it as hard as possible one time. He raearned the hard way when we started charging him for his tools.
    Proper lubrication as well as not spinning the bit too fast or applying too much pressure will keep a bit from burning itself up.
    But for bits I like chicago tools.
  4. 57Custom300
    57Custom300
    from Arizona
    Beat me to it. Used to hate to lend bits out to guys. Their idea of "drilling" was either to get the bit red hot or try to push the bit through.
  5. MATACONCEPTS
    MATACONCEPTS
    Practice sharpening the bits on a table grinding wheel. I got it down, when its not cutting, it take less than a minute & boom it's like the best bit ever. When newbies come over, I teach them that one quick when they start in with, "It not cutting".
  6. Texas Mopars
    Texas Mopars
    from Texas
    I used to watch guys destroy drill bits at a Halliburton ***embly plant using WD 40 for lube. I would sharpen the damaged bits on a grinder for them and then tell them to use water and slow the bit down! No more problems after that... Now on hardened steel like an Eddystone rifle you need cobalt bits and may even have to anneal the surface to get through.
    BD
  7. 53sled
    53sled
    from KCMO
    Stop blaming the bit, start going slower and using lube. You are welcome.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Just little tidbit I learned from Bob 'Gilley' Gillian. (Moldex Crank). You can drill a hole in a leaf spring with a HSS bit if you run it SLOW. He gave me a C-clamp with a 3/8" hole in the end of the screw. "Put the drill in the hole, tighten it on the spring and twist the drill with a pipe wrench or vise grips. When it stops cutting, tighten the clamp again."
    I miss Gilley
  9. bobss396
    bobss396
    I use drills mainly in CNC mills and the Bridgeport. The CNC mills use water-soluble coolant, I'll use the same with a brush on the Bridgeport, that also has a flood coolant set up on it.
    I've been using the above formula for years, cut the resulting RPM in 1/2 for reamer use.
    If a hole has to be accurate I give it a pilot hole first and step it up if I have to. Almost anything over a 1/4" gets a pilot hole as well. Really extends the larger drill life and doesn't add that much to a program.
    Bob
  10. ol fueler
    ol fueler
    That reminded me of something my Dad told me years ago---- He said that you could drill spring steel using HSS bits, slow speed and ELMERS GLUE for lubricant . Never had the need to try it but I'd bet he knew what he was talking about -- usually did!
  11. Blue One
    Blue One
    from Alberta
  12. Oldsmell
    Oldsmell
    If its cheap steel it will dull right away, HSS (High speed steel) is the common steel for normal quality, tool steel and carbide are harder and will last longer. Always keep them cool and keep RPM down to only what it takes to cut and not catch. use oil......
  13. firingorder1
    firingorder1
    I use inexpensive drill bits. But then I use them (mostly) in a press with lube and low rpm. And they last. I don't care if you have drill bits made out of unobtanium. Trying to feed a 1/2" bit at 24" a minute will kill it.
  14. 40FordGuy
    40FordGuy
    Grainger also has good ones,....They're an industrial supplier, and they do sell to the public.
    4TTRUK
  15. bobss396
    bobss396
    Many years my brother buys a couple of drill indexes full of new drills, they looked real nicely finished too. He goes to use one on a mild steel bracket, it just bent over the second he leaned on it... they were marked HSS, but they sure didn't act like it.
    Bob
  16. I stumbled upon a lube that seems to be working well. I got tired of the cutting fluid smell and grabbed a spray bottle I had in the shop. It was water and Murphys Oil cleaner. Works really well and smells even better.
  17. Belchfire8
    Belchfire8
    My brother did the same thing, 'cept he was drilling on the fender of his car when the bit bent over....yeah, nice circle carved in the paint.:eek: I'd never seen a drill bit bend!
  18. iammarvin
    iammarvin
    from Tulare, Ca
    Mistic Metal Mover. Yes. I laughed at the name too. Worked wonders over the other cutting fluid I was using when I had a bunch of small holes in stainless.
  19. Curt B
    Curt B
  20. banginona40
    banginona40
    I'm with you on that one.
  21. chinarus
    chinarus
    from Georgia
    No industrial supply places close to me with Sat hours but I have found
    the step drills at HF work really well on old Henry frame steel and are cheap but
    will break a cheap drill chuck if they grab.
    I have had pretty good luck with the Blue packaged cheap index coated set at Northern Tool as well.
    I use pilot holes, a slow drill speed, and sharpen when they get dull on a belt sander.
    The Milwaukee 3/8 variable speed drill tradesman is outstanding for the price and solved a lot of my drill bit problems. I use oil on thicker metal only when using the drill press for the most part,
  22. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Me too, I just sharpen them for a more aggressive bit.
  23. captmullette
    captmullette
    i agree on the step drills from hf, and i had trouble starting my holes and started using hex head self tapings screws, they work great even in my 1/4 tubing frame and you get a whole box for a couple bucks, oh yea , oil and slow....
  24. black 62
    black 62
    from arkansas
    all my bits 15/32 or larger are machine shop quality mostly from Grainger most everything smaller is "el cheapo" harbor freight gold when they have that 20 buck index for 10 bucks---seldom oil smaller bits or sharpen them ---mostly drill mild steel in a press or mill-- lean on them hard but rarely break one---when not in the press I u
    se less pressure and spray on drill lube--make sure to know disposable from quality and you will have a nice ***ortment of sharp bits as you complete your projects----most drill presses come with charts for speed and feed---no gloves around drills or drill presses--good luck
  25. falconwagon62
    falconwagon62
    Yep, 135 degree M42 cobalt. Real industrial machine shop stuff.......
  26. inliner2318
    inliner2318
    from Tyler, TX
    if it says china or taiwan. You will break half the set before they wear our.
    USA or Japan is the way to go. Good bits are costly and should be kept sharp and run at their proper speed. coolant too is the way to go.
