Technical 54 331 Hemi Rebuild
Discussion in 'Traditional Hot Rods' started by tankwilson, Sep 25, 2012.
  1. 270dodge
    270dodge
    from Ohio
    You say that your no expert! Well a****st George and 73 roadrunner I'll listen to you!
  2. 270dodge
    270dodge
    from Ohio
    I should have said including George and 73 Roadrunner I'll listen to you.
  3. tankwilson
    tankwilson
    Got the drivers side rockers all apart and cleaned. Gonna take them to the machine shop and see what they say. I think they are good enough to run but will make sure. Gotta take a piston up to them so they can get all the measurements for gary so i can order pistons.
    Whats the part number or where do i get the plugs for the ends of the rocker shafts?
  4. tankwilson
    tankwilson
    Time to start ordering.
    I need to get some machining done and measurements taken to order pistons. My idea is to order the parts that the machine shop can install and keep busy with while waiting for the pistons.
    My list so far....
    valves
    valve springs
    valve guides
    frost plugs
    cam cap and plugs
    intermediate bushing
    little plug to reroute oil to filter
    rod bolts
    main and head arp studs
    What else???? Not looking to order everything to do the complete rebuild.... just enough to keep the machine shop busy.
  5. slammed
    slammed
    One look: With a black engine, stainless fasteners, chrome valve covers, upper pulleys, air cleaner. Keep the attention drawn to the top end (strong suit of the Hemi) & centered. All around the engine compartment should stay black so it will 'disappear'. Scott Sullivan style. It will take on a industrial/minimalist look.
  6. 73RR
    73RR
    Dorman #555-011
  7. 41 C28
    41 C28
    Lots of information I'll will be watching and learning.
  8. Shane Spencer
    Shane Spencer
    i have a pic of an off white hemi with a 6x2 setup on it. looks *****in. whatever you do dont do ford blue or chevy orange. i think black always looks cl***y on a hemi. smooth the block out maybe ?
  9. tankwilson
    tankwilson
    Yea it depends on if I can get the motor to fit without cutting into my firewall too much. It is original Mopar pale blue. If I can keep that im gonna paint the motor a royal blue or something close. If not then im not sure. Will prob paint the firewall cream and the motor light blue and eventually the car a dark blue. Not sure yet.
    Sent from my DROID device using the TJJ mobile app
  10. Texas Mopars
    Texas Mopars
    from Texas
    That's a 5/8" plug isn't it?
  11. tankwilson
    tankwilson
    .29 a piece my cost. Nice to work for some one that ones an auto parts store.
  12. George
    George
    I think Ford Blue looks rather good, but I paint mine black.
  13. TR Waters
    TR Waters
    from Vermont
    Be sure to ask your machine shop about resurfacing the rocker tips.
  14. 73RR
    73RR
    Yes.
  15. tankwilson
    tankwilson
    How is that done???
    I just had my machinist neighbor (works at John Deere) check the rocker shaft and he says the shaft is probably wore down .001 Will bring home his other gauges to check the bore tomorrow.
  16. tankwilson
    tankwilson
    Who makes an alternator that looks like a generator that would look right for my engine or era???
  17. chrisp
    chrisp
    powermaster, dynalite, there are probably others.
  18. tankwilson
    tankwilson
    Got one rocker set done. Still need to resurface the ends but here's a pic for ya. Will cover the rebuild in future posts.
  19. tankwilson
    tankwilson
    This is why u knock out the plugs and clean the inside of the rocker shafts
  20. 73RR
    73RR
    ...sometimes the **** isn't even in a liquid form...
    Hey, it ran real good when we parked it, just fire that baby up...:eek:
  21. tankwilson
    tankwilson
    Get a can of carb cleaner, roll of paper towels, and ur gun cleaning kit and put on dark side of the moon. When the album is over then it might be clean
  22. tankwilson
    tankwilson
    Cleaning the rocker posts. Make sure u spend extra time on the one that has oil p***ages. Just when u think its clean.... clean it again.
  23. tankwilson
    tankwilson
    Rocker ***m clean. Arms are bagged up and ready for resurfacing. Plugs in one end. Will oil them and plug the other end during engine ***embly
  24. tankwilson
    tankwilson
    More thinking too much.....
    What air cleaner am i going to run? I have the stock one and thought about gutting it and putting in a modern element but its really kind of too big.
    Anyone got an old oil bath style air cleaner with an aluminum top with some design stamped in it?? Thinking about taking something like that and reworking it. Really wont know what im looking for till i see it.
    Any other ideas??
  25. tankwilson
    tankwilson
    Got the heads back from machine shop, no there not done, just clean. Gonna do some gasket matching and very minor clean up.
  26. tankwilson
    tankwilson
    Cleaned up the heads tonight. Ok only one so far. Did some grinding on the outside getting rid of castings and ready for paint. Also cleaned up the exhaust ports a little. Still need to gasket match and go back to the machine shop.
    coupe33 likes this.
  27. tankwilson
    tankwilson
    Got my gaskets today.
    So how do I "gasket match" ? Set the gasket on the head. Mark it. Grind to match gasket? What about the part of gasket that overlaps the hole? Exacto knife?
  28. George
    George
    Yeah, & hope the gasket is right....
  29. tankwilson
    tankwilson
    I just bolt on the intake and shot some paint down each runner painting the intake where the ports don't line up. U can see bout a 1/16" mark on the left side.
    Im thinking I will clean/open up the ports a little to help better flow.
    Does this sound right? Im not gonna go crazy but would like to match a little better
  30. 73RR
    73RR
    I'll take a slightly different approach on the 'need' to do much of anything considering that this is intended to be a daily driver.
    You have ports big enough to throw a cat through which means that velocity will be on the low end when the rpms are in 'cruze-mode' so making it even easier for the air to move may not be the best course of action. Keeping the air churned up a bit will help keep the fuel in suspension rather than letting it fall onto the floor of the intake.
    Any gasket protrusion or port mis-match just might be a good thing.
    my 2¢ ...other opinions will differ.
