Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. I would really like to see a pic of the rear axle attachment to the spring.
    That car is B E A UTIFUL
  2. banjeaux bob
    banjeaux bob
    from alaska
    Terry Rogers in his Frazer - Nash at Loton Park.Steve Wilkinson pic.
  3. banjeaux bob
    banjeaux bob
    from alaska
    1902 Oldsmobile ,Pirate.
  4. banjeaux bob
    banjeaux bob
    from alaska
    Art Smith in what looks like another Henderson powered midget.
  5. UKAde
    UKAde
    from Oxford UK
    Springs have arrived great looking vintage springs with tapered leaves with radiused ends
    Just have to drill them , before chopping them in half to make four quarter eliptics from two half eliptic springs ,
  6. UKAde
    UKAde
    from Oxford UK
    Some of the latest pics showing staggered seat
    <a href="http://www.flickr.com/photos/55288722@N00/8127636404/" ***le="Staggered seat back by little green austin, on Flickr">[​IMG]</a>
    <a href="http://www.flickr.com/photos/55288722@N00/8127611375/" ***le="Un***led by little green austin, on Flickr">[​IMG]</a>
    And the latest picture to turn up from the brooklands gazette
    <a href="http://www.flickr.com/photos/55288722@N00/8092896668/" ***le="From brooklands gazette by little green austin, on Flickr">[​IMG]</a>
  7. banjeaux bob
    banjeaux bob
    from alaska
    Ade,I like the timber framing!
    BanjeauX Bob
  8. banjeaux bob
    banjeaux bob
    from alaska
    More of the Baby Vanderbilt cars.Which,by the way,actually had Harley engines in them.
  9. banjeaux bob
    banjeaux bob
    from alaska
    Here you go Stevie... The C-6 Amilcar uses quarter eliptical springs.You can see the pivot connecting the spring eye to the differential.I'm sure the torque tube is the other connecting link.
  10. ebtm3
    ebtm3
    Beautiful woodwork, Ade!
    Herb
  11. Thanks, that's what I was wondering.
  12. banjeaux bob
    banjeaux bob
    from alaska
    Frazer Nash and Stefan Marjoram.Pic by Stefan via TheOldMotor.com
  13. banjeaux bob
    banjeaux bob
    from alaska
    Here's 2 Amilcar C-6s. Vincent pics via Vintage Revival Montlhery
  14. gnichols
    gnichols
    from Tampa, FL
    Is that his "Discover the World in a Frazier Nash" pose? Gary
  15. banjeaux bob
    banjeaux bob
    from alaska
    Gary,give him a shout.He's here on the HAMB and has posted to this thread.
  16. UKAde
    UKAde
    from Oxford UK
    Why do those Baby vanderbuilt cars run two chains to the rear wheels ,
    Two speed drive?
  17. banjeaux bob
    banjeaux bob
    from alaska
    I think they the power runs through the Harley transmission to a jack shaft.Then goes from there to the 2 chains.Like you're thinking ,one is probably enough.Kinda like on Formula 500 cars.My thought is that the 2 chains keep even load on the shaft.
    Harley had a 2 wheel arrangement for their 3 wheeled Servicars thqat would have worked great here.Then the center of gravity would be a bit higher.
  18. cleanslate
    cleanslate
    Howdy folks. I recently got the bug to build a cyclecar (hopefully in a few years) and while doing some research I came across this website and awesome thread. While I do like the look of the three wheelers (2f 1r) I really would rather have 4 wheels. My idea of what I want to build is something similar to what has been posted by sancta rosa (post #2635) as well as that posted by bubbfab (2623) on page 132 of this thread. I do have two old kawasaki 305's out in the yard and what I'm thinking is fabbing up a p***enger compartment with a frame and structure to attatch aluminum body panels to, while making mounts just rear of the seats to mount the motors (one on each side), and custom short swingarms that would mount up under teh motors, bringing the wheels right up against the motors. I love the looks of the morgan's as well as the old boattail roadsters, so I'm envisioning something that might be a combination of both. Of co****, on the other hand, I love the look of the old '27 Ford roadsters (the most beautiful of all of the old Ford roadsters IMHO) so maybe I'll have to build a scaled down version of one of those with an old farm tractor engine. I found a farmall cub power unit on craigslist for $500, so maybe something like that would be a great start. I'll figure it out as I get started.
  19. banjeaux bob
    banjeaux bob
    from alaska
    Welcome! cleanslate
  20. noboD
    noboD
    Carsonville? UMMM, french fries like a mountain. Does Elvis still live there, I used to work with him? Welcome Cleanslate.
  21. cleanslate
    cleanslate
    Yeah, tell me about it, the plate of fries they give you out there is a meal of its own. Yeah, Elvis is still around. I live about two miles from the hotel, so I'm not really "in" carsonville, but it's about the closest thing to me.
  22. chuxx
    chuxx
    Welcome Cleanslate, all your ideas sound cool and worth pursuing. Glad you mentioned SanctaRosa, you still out there Sister?
  23. cleanslate
    cleanslate
    Thanks Chu**. I've had the wheels turning nonstop since I started checking out this thread. One thing that I am pretty well decided on is having twin 305cc motors (since I happen to have a pair sitting on my workbench under about 1/2" of saw/sanding dust) and mounted out back. The problem is they're air cooled so I'd need some air ducting, shrouding and probably some sort of cooling fans to force air into them. I've pretty much decided that I'm just going to use the motors and not the rest of the bike frames. This gives me the option of either going with A) a swingarm (one per motor) mounted up under the motors to keep everything shortened up a bit, or B) mounting the motors on the swingarms themselves, kinda like the fun karts that tractor supply sells. I'm thinking that option A is going to be easier on account of it already needing to have some complexity for the throttle, clutch, and shifter controls. I do like the idea of having twin swingarms to go along with the twin motors. Advantages that I could see would be true posi rear, independant rear suspension, as well as having four wheels, instead of three. The swingarms would be designed similar to a tubular a-arm on an ifs car, only on a larger scale and turned 90*. I've been going over some ifs ideas in my head pretty much all day as well. One thought was to make a scaled down tubular version of of the old Ford twin I beam ifs found on the '70's trucks. The other idea that I had was to have a straight axle that would be cut in the middle to pivot giving me an ifs. Then there's the dilema of how to spring the front and rear. Coil over shocks would be the easiest, but I really like the idea of using a torsion bar set up like a sprint car or midget race car a whole lot better. That shouldn't really be all that hard to do or to get the parts for either as a friend owns a local dirt track supply buiseness, so I could always stop in at his store to check out the frames and eventually do some shopping. Nontheless, this build is going to be a long ways off according to finances. Hopefully a year from now I can start on it, but that may be dreaming as well.
  24. banjeaux bob
    banjeaux bob
    from alaska
    1935 Morgan as seen on ebay UK. Starting at 25,000 pounds.
  25. Huvius
    Huvius
    from Colorado
    So who built the Baby Vanderbilt cars?
    They all look to have the exact same ch***is.
  26. banjeaux bob
    banjeaux bob
    from alaska
    Aviator Art Smith and the San Francisco Harley Dealer.You're right about the identical ch***is.The idea was to mimic the BIG Vandebilt cars in looks only and put on a show!
    When I was a kid the toymaker IDEAL built a slotcar type affair called Motoriffic.There was one ch***is and several dofferent interchangeable bodies.Same idea.
  27. 1935? sure looks alot earlier...1915?
  28. BORED
    BORED
    from BOERNE,Tx
    Does a 1984-1987 Harley Davidson "Tri-Hawk" 3 wheel reverse trike qualifiy?
    (red one in pic below)
  29. banjeaux bob
    banjeaux bob
    from alaska
    I'm a poor reporter,I only write the info I'm given.
    Anyways...enjoy the pics Doug!
  30. cleanslate
    cleanslate
    Guys, Ive tried doing a google search on this and couldn't find anything. Maybe I'm just not patient enough, maybe not. Where could I come across any information on any reproduction, NOS, or even used vintage mechanical dampers like I see on so many of the vintage rides in this thread. I'd love to put some of them on mine when I get to building it, but can't seem to find any info on them. Thanks in advance.
