1956 Pontiac Chieftain wagon 4 door
Discussion in 'The Hokey Ass Message Board' started by fifty5rod, Aug 12, 2011.
  1. fifty5rod
    fifty5rod
    from El Paso TX
    any advice on keeping the original 316 or swapping a 350 chevy?? Any pictures out there??
  2. Xtrom
    Xtrom
    from Forman, ND
    Stick with the original engine. Everyone has a small block.
  3. bryan6902
    bryan6902
    I ***ume this is a US market Pontiac/not Canadian? You can do a Chevy or wahatever else you want but you'll have to find an adapter or fabricate side engine mounts. Pontiac used the front mount up to 59, so any engine 55-59 should be a bolt in.
  4. 55chieftain
    55chieftain
    I mounted a 60 cover, standard coolings first year and steel cover to a 66 389. The 60 cover to be mated up and using the bracket and front mount to about any year/set up Pontiac to take care of the front mount. Than some rear side mounts would still need to be made.
    Fabricating side mounts would be easier for a newer side mount Pontiac engine. Swapping out for a 350 would be out of the question for me.
    Whats wrong with the 316?
  5. Mule Farmer
    Mule Farmer
    from Holland MI
    keep the 316. I had one in mine ran great.
  6. ponco 56
    ponco 56
    350 chevys in old 50's hot rods make me yawn!! keep the 316! love the stance of your wagon ,what did you do to get her down in the dirt?
  7. henry's57bbwagon
    henry's57bbwagon
    As a Chevy guy I say KEEP it all Poncho.
  8. black 62
    black 62
    from arkansas
    why struggle with oddball engines ---if it is in good shape use and enjoy---if not sbc for all the well known reasons
  9. jrdeleon0430
    jrdeleon0430
    Keep it Pontiac, whether that means sticking with the 316 or getting a Pontiac 350 or 400.
  10. Rusty Heaps
    Rusty Heaps
    ditto!
  11. kennb
    kennb
    Don't know anbout the rest of ya, but I'm sick of looking at SBC's
    Ken
  12. Wagonmaster2
    Wagonmaster2
    Put a 389 in it. Then tell everyone it's 316!! LOL!
  13. Crusty Chevy
    Crusty Chevy
    I have Mule Farmer's old 56 wagon, and yes the 316 is a good motor, 220 horse is enough to get the wagon moving in a hurry when tuned right. I now have it with a modern 500 cfm Edelbrock 4 barrel on a tapered Speedway motors adapter to an original small bore four barrel intake. Its getting tired, a bit smoky through the breathers and could use a rebuild but even so it is still is a stump puller. I have read that early on V8 Pontiacs had problems with bad ring metal and they would break, I am probably going to pull it apart and see if that is true in my case, could just use an old fashioned ring job. Stock auto ****** is pretty tough and takes a beating pretty good. If yours it isn't wasted I would try to work with it. A new 350/350 would cost as much as a little investment in the 316 which BTW is all forged internals crank, rods and pistons; try to get that in a 350 for less than $5K
