Can someone ID these valve covers? Lincoln Y block or early '49 Cadillac?
Discussion in 'The Hokey Ass Message Board' started by Black Panther, Oct 25, 2012.
  1. Black Panther
    Black Panther
    from SoCal
    Picked up these valve covers at the swapmeet...heavy sand castings...no names or marks on the inside...the center to center on the hold down bolts is 11 5/8" the bosses under the hold down bolts are slightly angled which means that the part of the head where the bolt goes is not straight down..probably angled downward towards the lower part of the head. The gasket area is 19 1/2" long by 4 5/8" wide...does anyone have an early Cad or Lincoln Y block they can measure to make sure? Thanks!
  2. Studebaker maybe?
  3. propwash
    propwash
    from Las Vegas
    studebaker was four bolts
  4. F&J
    F&J
    Check with Tommy, I think he has pics of Stude 2 bolts and 4 bolts.
  5. redo32
    redo32
    Looks like Chevy Vortec using only the end bolts. The gasket measurements are right, but I don't have a set handy to measure the center bolts.
  6. plymouth1952
    plymouth1952
    I have to agree they look like chevy:eek:
  7. stillrunners
    stillrunners
    from dallas
    yes Stude did go to just two around 1961 or so....
  8. They are not early Cad as they measure up at 13 7/8" bolt centres and 5"x 20 1/2" gasket area. Plus the hold down bolts straight into the heads.
    Hope this Helps.
  9. tommy
    tommy
    how about some 6 bolt Studebakers?
    They could be early Olds also. That is what these were originally mounted on but they fit Studes if you drill the four other holes. The four in a row are the Studes. The two higher up are dummies and were used on the early Olds. This is a 4 bolt 58 engine. The Lark era engines were 2 bolt. These show up in a 52 Wieand catalog.
  10. vintagetinman
    vintagetinman
    They aren't Lincoln y-block rough measurements are 14 inches between bolt centers and 5x20 gasket surface
  11. Black Panther
    Black Panther
    from SoCal
    These valve covers are probably 50+ years old..they just had a recent polish job...so not Chevy vortec in any way...there was a thread on here from 5-7 years ago with exact same covers that were never identified...hope these are...
  12. propwash
    propwash
    from Las Vegas
    I bow to the late Stude experts - I'm old, what do I know from Larks?
  13. F&J
    F&J
    Measured 2 different brands of Olds Rocket covers at 10-5/16" on centers.
    I did not think they were Olds because yours appear to have 4 matching curves on the gasket corners...On Olds covers, the top corner curve would not match the bottom curve.
  14. Black Panther
    Black Panther
    from SoCal
    Can anyone measure a two bolt Studebaker?
  15. Hotrodbuilderny
    Hotrodbuilderny
    Not Ford y block 13 1/2 c to c on bolts
  16. F&J
    F&J
    If nobody can, try to find a piceture of one. Look at Tommy's pic of the 4 bolt ones that were also designed for Olds...they have those unmatching curves on upper vs. lower corners.
    Yours look like all 4 corners have matching curves? I am thinking the 2 bolt Stude might have unmatching corners as well?
    Would an overall width/length of the late 49 Cad help? I have those at the shop, but they are the perimeter bolt style.
  17. FrozenMerc
    FrozenMerc
    What about Buick Nailhead??? The width is right, but I don't know about the hoel pattern or length.
  18. slacker1965
    slacker1965
    my '64 401 nailhead measures 11" c2c.......
  19. donut29
    donut29
    from canton MI
  20. tommy
    tommy
    The 2 widest bolts are 13 5/8" CC. Since they hold the rocker shaft, they should be the same for the 2 bolt later VCs that just eliminated the center two bolts.
  21. Black Panther
    Black Panther
    from SoCal
    I was told by the guy I got them from that they were Nailhead..and the nailhead specs are close..but no cigar. He also had one that was in original condition that looked REALLY OLD...like 50s made or very early 60s. If someone can measure a 215 that might be good...
  22. aerorocket
    aerorocket
    from N.E. P.A.
    . If someone can measure a 215 that might be good...[/QUOTE]
    215 is totally different.
  23. cwheelin
    cwheelin
    Got a 215 and the dont have the holes in the center like that
