This is for a few of my IG friends. Some of you guy will remember the frame table I built for tech week. Well Iv put into good use. I started with a stock frame but the rails were pretty rusty so I ordered some from ASC. I used Ionia boxing plates and the stock X member model A front and rear cross members. Center was modified to clear a Muncie trans and riveted back in place then welded. Front rails I doubled the boxing plates to make doing the motor mounts easier. I will update with more pic as I get more stuff done
Here's a quick little mock up we did the other night. I'm using a 37 truck grill so that's why the frame was pinched and the horns cut off. I plan on chopping it around 5 1/2 in the front and 5 in the rear also going to lean the pillars back quit a bit. Planning on a aluminum hood, Hood sides, Roof insert, Deck lid and roll pan punched full of louvers.
hey look at that!! i can see the pictures big finally instead of putting my iphone close to my face !! nice work my man!!
Here's a few more pics. I got some work done on the bottom side tonight. Had to make some room for the spring.
Yes yes yes!!!!! I was hoping I was gonna see this thing coming together in large format! Great work buddy, you have really went above and beyond on that ch***is.
Thanks for the props. I'm just trying to do the very best I can Posted from the TJJ App for iPhone & iPad
