Winter is here time for "The List"
Discussion in 'The Hokey Ass Message Board' started by BronxMopars1, Nov 2, 2012.
  1. BronxMopars1
    BronxMopars1
    from Bronx, NYC
    SO who else has a "List" of things to do on therre ride this winter? So far mine consists of:
    -Raise suspension
    -leaking coil over
    -Replace oil pan
    -mechanical fuel pump
    -finish asphalt wire loom
    -powder coat door panels
    -better seat foam
    -vintage hose clamps
    -paint trunk
    -oil change
    -make marker light work
  2. tb33anda3rd
    tb33anda3rd
    my list consists of a total rebuild of the car BOTH my father and i drove to high school.... it has sat too long. i have a pile of stuff collected and the two of us are looking forward to doing it.
    my wife has a list of "honey do's" of house restoration projects that would send the crew of "this old house" screaming off into the night.
    wish me luck!
  3. dirt slinger
    dirt slinger
    I feel your pain on those honey do's. I might could get a project finished if I could finish the widest list.
    Sent from my DROID device using the TJJ mobile app
  4. I got a few myself:
    Rebuild rear suspension
    install split exhaust manifold and build exhaust
    install 3spd overdrive trans
    recover seats
    do some minor body work.
    Now I just need to stop driving it so I can start the work!!
  5. eddie1
    eddie1
    63 Chevy C10 has a few issues to work out.
    Change the throttle linkage so I can get full throttle.
    Install the stereo system that in the last minute thrash to get the truck on the road this summer did not get done.
    Recover the seat in something more era appropriate instead of the black & gray cloth that looks like it belongs in a 1983 C10.
    Replace the wood box floor.
  6. Tin Can
    Tin Can
    -Bleed brakes
    -Extend front inner fenders
    Install
    -Winshield
    -Hood
    -Hood springs
    -Wing windows (after slight adjusting and paint, figure out crank)
    -Finish up garnish mouldings
    -side gl*** with the regulators
    -Fan shroud
    -Vac***e line booster to carb
    -fabricate a rear license plate mount
    -Get headliner and door panels done
    -Do carpet myself
    -Clean up car, do some more sanding and buff the entire thing out again.
    -regulators for air ride to slow down the dumps
  7. Todd ( Tugmaster ) can tell you what I'm doing, A new 9+3 wire harness from Rebelwire. Gonna rewire the 29 the right way. Just waiting for the mailman to bring it, right Todd.:D
  8. Stevie Nash
    Stevie Nash
    1) Lower rear end another inch.
    2) Paint engine
    3) Install engine/transmission
    4) Install (switch to) power steering rack
    5) Install radiator
    6) Install front sheet metal
    7) Paint running boards
    8) Paint/install dash
    9) Install steering column/wheel
    10) Install trunk hinges
    11) Reupholster interior
    12) New carpet
    13) Fab/install new exhaust hangers
  9. BronxMopars1
    BronxMopars1
    from Bronx, NYC
    Tin Can that thing is SWEET&SLICK!
  10. FrozenMerc
    FrozenMerc
    There is just one big item on my list...
    #1: Get the Mercury out of my garage and into the painters.
    Of course, there is alot to do to get it there. But with the 2nd big snow fall of the season this morning, I don't have to worry about taking the '51 F-1 out any more.
  11. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    rewire complete truck with Rebelwire system I got over the summer
    rebuild power steering rack (more likley have it rebuilt)
    Pull motor, smooth firewall on truck, paint firewall and inner fenders.
    install new motor
    paint interior of truck and get seat recovered
    pretty ambitious list on my end, but hopefully with my new job schedule ill have the time and the $ to pull it off.
  12. slamnfreak
    slamnfreak
    from Washington
    I want to get the replacement trans. freshened up and ready to install, rebuild one of 2 engines (not sure which engine I'm going to run, yet), repair the dash and floorpans, and redo the front suspension.
  13. need louvers ?
    need louvers ?
    Drive Drive Drive! It's winter time dudes, I can finally go out side again! It is a whole lot more pleasant in the shop though when it's under 125 or so!
  14. 100% Matt
    100% Matt
    58 F100: Clean up the firewall, rewire, finish body work on the bed. Install a dual m/c, Dress the motor
  15. BronxMopars1
    BronxMopars1
    from Bronx, NYC
    -Raise suspension.......... Check
    -leaking coil over............ Check
    -Replace oil pan............. Check
    -mechanical fuel pump.... Check
    -better seat foam
    -vintage hose clamps....... Check
    -paint trunk
    -oil change..................... Check
    -Add orange fog light
    -Change intake Manifold
    -Remove Power booster from brakes
