60 caddy running like terd, advice appreciated.
Discussion in 'The Hokey Ass Message Board' started by 50bomb, Nov 5, 2012.
  1. 50bomb
    50bomb
    from Lodi CA
    My beautiful 1960 cadillac was running great. It sat for couple months then went to drive it and was loading up, sputtering, and had some black smoke from exhaust. So, I gave it a tune up. Plugs, wires, cap, rotor, checked timing, oil. Has pertronix so points are out. Still ran terrible. Check vacuum with gauge and for any vaccuum leaks around carb base. Nothing. Carb was rebuilt last year and probably has 300 miles on it. So I put new edelbrock carb on and re adjusted everything. Still runnin like a terd, sputtering, stalling, and smells like flooding out. Any advice or knowledge would be greatly appreciated!!! Thanks hamb.
  2. 50bomb
    50bomb
    from Lodi CA
    Forgot to mention, compression is good, no knocking, and at 50-75mph is runs pretty decent.
  3. 40FordGuy
    40FordGuy
    "Sat a cpl of months"......Given the "quality" of today's gasoline, I'd try some fresh fuel, and see what happens. Do the easy stuff first.........
    4TTRUK
  4. Dreddybear
    Dreddybear
    Change the fuel filter too.
  5. 50bomb
    50bomb
    from Lodi CA
    Yes! And fuel pump is working properly. Fueled it full with fresh premium and put cleaning additive.
  6. 40StudeDude
    40StudeDude
    I'd say it's today's ****py gas...I just had to have my gas tank boiled out because my car sat for almost a year... had to overhaul the carb, put on a new fuel filter and clean the hard lines to the tank...that **** tends to gum up everything...
    R-
  7. plymouth1952
    plymouth1952
    pull the valve cover and look for a bad spring
  8. Southmark
    Southmark
    Had similar problem. After trying everything else, took out Pertronix, put in points and condensor.............problem solved. Even though the Pertronix tested OK!
  9. 50bomb
    50bomb
    from Lodi CA
    Wow! Never thought pertronix would be the problem. I'll try pulling valve covers first, good to check anyways. Then I'll go buy the points and give it a shot.
  10. In a few months time - the hard parts changing or failing is highly unlikely.
    The gas changing in that amount if time is 100% certainty.
    The fuel causing deterioration to the soft parts in your fuel system has a high probability.
  11. ugotpk
    ugotpk
    Do you have 12 volts? Add a jumper wire from Batt to coil +. If it's not bad fuel. Then you have poor ignition!
  12. bobss396
    bobss396
    I'd start with the stock carb rebuild, try to do 1 thing at a time so you know what it was.
    Bob
  13. Abomination
    Abomination
    I'm with Jeff K. and bobss396 - Why the hell would anyone use a new Edelbrock versus the stock Carter?
    ~Jason
  14. flynbrian48
    flynbrian48
    Uh, because (in the case of the three that I've used) they work great right out of the box, and for less than getting an original rebuilt. And, since I **** at rebuilding carbs, it's better than me working for hours on an original, and having it run the same, or worse.
    Just say'n...
    Brian
  15. 50bomb
    50bomb
    from Lodi CA
    I put edelbrock on in a moment of despair! It's supposed to be in a wedding this weekend and I had a new edelbrock 1604 sitting on shelf. Trying anything at this point. Tomorrow I'll put points in it. Pertronix has been on for few years and ran fine, but we will see what happens. Thanks for input!!
  16. bobss396
    bobss396
    For some of us, the stock Caddy carb rebuild is pretty straight forward, for others.. not. This is one of the easier carbs to go through even for a novice.
    Bob
  17. Edelbroke
    Edelbroke
    I've got a 60 Coupe Deville, and the previous owner threw an Edelbrock carb on in place of the carter which needs a rebuild which I have in a box. No probs other than the lack of the hook up for the p***ing gear rod (or kick down)
    Sorry, no advice on why yours is running bad
