Need your help Hamb
Discussion in 'The Hokey Ass Message Board' started by Vlopez22, Nov 6, 2012.
  1. Vlopez22
    Vlopez22
    I need your help HAMB, I have a 1951 Merc with a chevy subframe and having trouble finding the right rim to put my 1957 Caddy hubcaps, i need a 15 inch 6 lugg rim or does anyone know what I can do? thank you
  2. chevyburb
    chevyburb
    Not knowing the bolt pattern, not sure, but '55- Chevy trucks used a 6 bolt, 15" rim
  3. Vlopez22
    Vlopez22
    Chevyburb its from a 2004 Chevy tahoe, do you know where can I get a 55' chevy truck rim?
  4. robyyo
    robyyo
    from Orange CA
    I've got some 6x5.5" steel rims, PM me if you need em.
  5. CharlieLed
    CharlieLed
    Lots of wheel manufacturers in your area, I would have a wheel made to your specs...a little higher cost but a lot less PITA searching for an OEM wheel.
  6. Vlopez22
    Vlopez22
    Where can I look Charlieled, I'm in the san fernando valley (818)
  7. V4F
    V4F
    from middle ca.
    there is a shop in morrobay
  8. Vlopez22
    Vlopez22
    do you have their number Steve?
  9. The wheelkid is on your coast he is here on the HAMB. Even if he wasn't on your coast he is only the big brown truck away.
  10. Jalopy Joker
    Jalopy Joker
    looks like your unique front clip has a 5.5"/139.7mm bolt pattern. should be plenty of options out there.
  11. V4F
    V4F
    from middle ca.
    pm sent
  12. Vlopez22
    Vlopez22
    thank you steve
  13. Vlopez22
    Vlopez22
  14. Vlopez22
    Vlopez22
    Looking for 16 inch Sombreros hubcaps I believe from 1948-49 no luck in finding them, does anyone out know of any?
