Wont stay alive.
Discussion in 'The Hokey Ass Message Board' started by Hillbilly_Deluxe, Nov 5, 2012.
  1. Hillbilly_Deluxe
    Hillbilly_Deluxe
    from Florida
    Hello all,
    Got a new valve in my 49 Plymouth flathead 6 and got it all put back together. Ran a new line to a portable gas tank until I can drop the other one and make sure it is clean. I am still having the same problem as I was having before my valve stuck.
    The car will run fine for about 10-15 mins. the starts dying. Have to use the choke to keep it running until it finally dies. Then have to choke it to restart it. Will run fine for a while again until it starts acting up again. I thought that there might have been some **** in the tank blocking the fuel line/in tank filter but that is not possible now as I am running a portable tank with a new line.
    Any suggestions?
  2. BadgeZ28
    BadgeZ28
    from Oregon
    Fuel Pump? Carb heat soak?
  3. oldsmobum
    oldsmobum
    from SoCal
    Sounds to me like it is a fuel related issue... Since keeping the choke on helps it run, maybe its a lean condition? Vapor lock? Check fuel lines, make sure they are an appropriate length, and not unnecessarily close (within reason) to a significant heat source. Kinks in the fuel line on the send side can have this effect... Ask me how I know. I would also check the fuel pump. How long are you waiting before you start it back up again? Hopefully someone wiser than I will chime in soon. Good luck
  4. tjmercury
    tjmercury
    It sounds stupid, but on the wife's DeSoto, i was having similar issues. After replacing the fuel pump and rebuilding the carb, the problem continued. Come to find out, it was the brand spanking new gas cap I put on wasn't venting and pressured up the tank causing vapor lock. Just my 2 cents
  5. servi53
    servi53
    intake leak?
  6. Skeezix
    Skeezix
    from NorCal
    Mine did that too - fuel cap maybe - mine was solved with carb rebuild - all funky inside
    Be sure all rubber lines are new too
  7. Hillbilly_Deluxe
    Hillbilly_Deluxe
    from Florida
    I took the fuel line off after it died and there was no gas coming from the pump when I turned it over. Can a mechanical pump have on and off failure like this?
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep if there is a piece of **** floating around inside and once in a while getting caught in one of the check valves.
  9. Clevername
    Clevername
    Rig an 'el cheapo' electric fuel pump -make sure it is not a fuel injection pressure one.
  10. Skeezix
    Skeezix
    from NorCal
    Also the diaphragm inside the mech pumps degrade - try and electric pump
  11. RAG66
    RAG66
    from WASHINGTON
    Yes a fuel pump can be off or on. That is a good reason to install a filter before the pump, not just the pickup screen (tube sock) in the tank on the pickup tube. You also should get all brand new rubber fuel line. That will eliminate that piece of the puzzle. The metal line can be blown out. Start at the tank and work your way to the carb.....
  12. Hillbilly_Deluxe
    Hillbilly_Deluxe
    from Florida
    10-4. I will take the pump apart tomorrow and see what I can find. I have thought about going electric as I have read vapor lock is a big problem on these cars. Thanks for all the advice.
  13. Hillbilly_Deluxe
    Hillbilly_Deluxe
    from Florida
    Converted to an electric fuel pump system and now it stays running!
  14. Skeezix
    Skeezix
    from NorCal
