Anyone have a hallock windshield frame?
Discussion in 'The Hokey Ass Message Board' started by nick_c, Nov 2, 2012.
  1. nick_c
    nick_c
    from texas
    I have a rough casting and need to know How deep and wide the groove for the gl*** needs to be milled out. I've seen a few threads on how to ***emble them but could not find them with the serch engine. Just would also like to see how other folks put them together.
    Anyone have a link?
  2. nick_c
    nick_c
    from texas
    Any one have a hallock and a set of calipers?
  3. bob giles
    bob giles
    Do a search for Steve Sellers. He re-pops them and can answer your questions and also has the rubber.
  4. Slimegreeeeeen
    Slimegreeeeeen
    I believe Steve is no longer making them, although he might have a few still in stock.
    Hit up his Facebook page (Sellers Equipped) and send him a message. Not sure whether he's ready to give out measurements. Good luck.
  5. Murocmaru
    Murocmaru
    from Van Nuys
    I have a boat windshield at home. It's probably a similar measurement. I'll check it out when I get off work if you havent heard by then
  6. nick_c
    nick_c
    from texas
    Yea I have tried that. I got the raw frame from Steve and he's out of buissness. I've Got to figure out how to do it in my own.
  7. sideshowrob
    sideshowrob
    from australia
    ive got one of steve's, i'm not near the car for a week or two, if you can wait till then then i can give you any info/photos you may need, send me a pm if you get stuck. rob
  8. Kirk Hanning
    Kirk Hanning
    I've got a Hallock w/s frame from Steve Sellers that I have yet to install. Luckily the window groove is already cut in. The measurements are a .375" (3/8") wide groove by .390" deep. The .390" deep groove does vary a bit but I'm sure machining around the contour you would expect that.
  9. nick_c
    nick_c
    from texas
    Is there rubber that is samwiched with the gl*** and the frame or is the gl*** just glued in the frame?
  10. Kirk Hanning
    Kirk Hanning
    it never came with instructions but I would ***ume you'd get U-shaped rubber to sandwich in the channel with the gl***. I have never seen 3/8" wide gl*** (well yes I have seeing that I'm near both Detroit & Flint, MI). Not only that but the rubber would provide a cushion for the gl*** as it'd crack for sure against a vibrating aluminum frame.
  11. Blue One
    Blue One
    from Alberta
    Save your time and don't contact Sellers. I believe he has gone out of business anyway.
    I contacted him about a Y Block valley pan and was treated to a variety of psychotic responses when I mentioned the Hamb. :D
    He offered first to sell me one, then said the wait would be about 6 weeks, then basically told me he was closing the shop down.
    Based on the rambling nature of his responses to me ( He was all over the map and didn't even seem to remember previous correspondence over the course of just a few days ) I'd say he has some other issues.
  12. nick_c
    nick_c
    from texas
    I wrote him tons on emails after he had for my money with no response and finally only got a reply with a hand written letter.
  13. nick_c
    nick_c
    from texas
    So this is about right. One guy gets the rubber for the window channel. One guy did not.
    And mine is a rough casting and I have to fill in all the blanks.
    Where can I get the rubber? I'm guessing it's about the same as any per war ford?
  14. George G
    George G
    I have a bronze cast hallock that I have yet to work on. Milling out a groove sounds like it it will be nothing but heartbreak.
    Why not just glue the gl*** into the ungrooved frame?
    It's not going anywhere.
  15. alchemy
    alchemy
    How would you do that? Show me a sketch or something please.
  16. nick_c
    nick_c
    from texas
    There is nothing to attach the gl*** to.
    Anyone have an idea on the rubber?
  17. AREA51SD
    AREA51SD
    Steel Rubber has one that fits a 3/8" groove, but the gl*** will be 1/4" thick.
    the part # 70-2642-57 buy it by the foot. they are located in Denver, NC (800)230-5871.
    PB
  18. George G
    George G
    Simply cut the gl*** so it fits in the frame's flat surface with no pinch points. Not an interference fit. Then lay in a fillet of caulking material, let it cure then turn the windshield over and repeat.
    Yes it will work. No you won't die from lack of a groove
  19. curbspeed
    curbspeed
    My windshield gl*** was put into mine using black urethane in a caulking gun. Fill channel with it. Set gl***. Wipe of excess. Let dry and clean up with with a razor blade. Bam! Done.
  20. Kevin Lee
    Kevin Lee
    Super Moderator
    True, but you might die from catching a windshield in the face?
    I would equate this to: "The fall won't kill you... it's the sudden stop at the end."
  21. alchemy
    alchemy
    Yep. I'd sure like to be ***ured there's some mechanical force holding the gl*** (edges of the groove) rather than just some glue.
  22. alchemy
    alchemy
    This is a great method. That stuff will fill the void and solidify like a molded gasket. But a good thing to do before you spread the goop is dry fit the gl*** to make sure there will be no edges touching the metal frame at all. And before you place the gl*** and goop, cut some small little spacers of rubber (innertube maybe) to separate the gl*** from the frame at the tight spots. Then fill the void. If you trim the spacers small enough they won't show.
  23. NOTCH
    NOTCH
    I have a good friend that supplied steve with the rubber and its from a Vw bus window
    He manufactures front safaris windows and I belive he purchases the rubber in a large roll, not sure where he gets it but I can contact him.. Me and steve were good friends at ONE time. bummer..
    and If anybody is interested in a dash rail to fit for the hallock, let me know , I have one for sale.Notch
  24. bob giles
    bob giles
    Steve Sellers made frames with two sizes of groove. I contacted him 2 years ago and he recommended using the rubber that he had for sale. He sent me the rubber but it got lost in the groove. Thats when he remembered that they were made with diferent size grooves.
    I had a regular gl*** guy cut and install my gl***. He recommended using clear silicon and gluing them in. He thought if they ever broke, ureathene would be dificult to clean out. Mine are two years old with no problems
  25. nick_c
    nick_c
    from texas
    Your frame looks super clean installed.
    Is there something in between the frame and the cowl top?
  26. bob giles
    bob giles
    Nick c, I glued 1/4X1/4 angle rubber around the base of the frame
  27. NoLifeTilLeather
    NoLifeTilLeather
    Nick, if you decide not to go through with the HAllock for some reason, lemme know - I'll buy it off you! :) Havent been able to get in touch with Steve...
  28. nick_c
    nick_c
    from texas
    Yep he's out of business.
  29. deto
    deto
    Not trying to hijack the thread but what happened to Steve?
  30. nick_c
    nick_c
    from texas
    I'm not sure.
    But I was wondering my self
