s10 rear axle
Discussion in 'The Hokey Ass Message Board' started by unearthly57, Nov 7, 2012.
  1. unearthly57
    unearthly57
    does anyone know the stock size u-bolt for a s10 rear axle. what is the length? i know the wire size(thread size) is 9/16 and the ID is 2 1/2". should i go with a 3" ID instead?
  2. scrap metal 48
    scrap metal 48
    I don't know the stock size but the round axle housing is 2 5/8" wide so I'm guessing a U-bolt with a 2 3/4" ID....
  3. unearthly57
    unearthly57
    yes, thats right
    common wire size is 9/16
    ID 2.75"
    length is 6" stock
  4. chaddilac
    chaddilac
    Take the original ones and have a spring shop make them longer or whatever you need. They are pretty good at doing that and they'll get it right on the money.
  5. unearthly57
    unearthly57
    i dont have the originals. when i bought the axle i bought it from a used parts dealer, they junk the hardware usually. and auto stores go by length wire size and ID. i dont know s10 very well so i was hoping someone here did. but i figured it out through other websites.
  6. Jalopy Joker
    Jalopy Joker
    so, what are installing this rear in?
  7. themoose
    themoose
  8. unearthly57
    unearthly57
    i got a 96 s10 blazer rear the 3.42 and its getting put on a 57 chevy pickup with 3 inch drop springs. i put the new leaf spring perches on top of the axle to avoid notching the frame.
  9. unearthly57
    unearthly57
    i used this website for a reference. napa auto parts has 9/16 threads, 2.75 ID and 6 3/8 length ubolts in stock.
  10. Jalopy Joker
    Jalopy Joker
    so, springs running above rear? 3" drop from stock ride height would not likely require a notch.
  11. unearthly57
    unearthly57
    stock s10 rears sit on top of the leaf springs, opposite of a normal full size chevy. i cut mine off and relocated them to the top of the axle. so now the rear will sit under the rear leaf springs. the trucks rear suspension will look like a stock 57 but with a 3 inch drop.
    if i kept the spring perches on bottom of the s10 axle (relocating them to the correct width of 57 stock spring location) and put the s10 axle ontop of the new 3 in lowered spings i would have ended up C-notching the frame, which i had no intention of doing.
  12. 1971BB427
    1971BB427
    from Oregon
    The local spring shop nearby makes up U bolts while I wait for $7-$8 each with nuts and washers too.
  13. scrap metal 48
    scrap metal 48
