1953 buick chop question..
Discussion in 'The Hokey Ass Message Board' started by xristosk22, Nov 7, 2012.
  1. xristosk22
    xristosk22
    i have recently got a 1953 buick special which i plan on turning into a kustom. i plan to chop it 4or5". my question is if i slant the b-pillars forward would i still be able to make the rear windows roll up and down. also I'm having and a problem with my blinkers not working and one of my break light constantly stays on and the other works. I've been looking for a wiring diagram and i can't find it on here. does anyone know if there's one on here or where i can get one.
  2. OldKustoms
    OldKustoms
    Hi,
    maybe this can help you:
    Bye
    Marcel
  3. xristosk22
    xristosk22
    thank you Marcel ill check it out.
  4. Greaser Bob
    Greaser Bob
    Special cut gl*** and serious engineering maybe you could make the windows roll up. Maybe if you could make them come up at an angle as a whole, it would work?
    By the way, I've chopped these cars before and it is involved but I know you'll do fine:)
  5. hotdamn
    hotdamn
    just some unsolicited advice, you may want to start cutting at 3" and work your way down, 5" is getting mail slot esq.
  6. Jalopy Joker
    Jalopy Joker
    5" - Wow, good luck with that. hope that this is not your first chop. be sure to figure out front and rear gl*** before doing anything. next side gl***. wiring should be easy.
  7. chaos10meter
    chaos10meter
    from PA.
    Don't touch front and back window size if you can help it.
    The back side windows can be made to work but it's a pain & costly.
    I just did a 6" chop on a car and the owner decided it wasn't that important to have working back windows when he found out the cost so we just glued them into the window channel and done.
  8. Jalopy Joker
    Jalopy Joker
    see thread: 53 Buick Chop Started
  9. mrjynx
    mrjynx
    Ive never chopped anything but cant you make the gl*** in the rear quarters move backwards as they move down by making a custom runner? kinda like the pic.
  10. Gator
    Gator
    from Statham Ga
    I'm with Hotdamn on the chop - 4-5 is gonna be WAY too much. I had a same year Caddy that was over-chopped by the previous owner.... I'd have rather had the car UN-chopped. The idea is a lower, sleeker look, not to look like a cartoon. It's all about PROPORTIONS.
    For the windows, look at a tri-five Chevy rear, they curve down at an ante as they roll down. Here's the track;
  11. Greaser Bob
    Greaser Bob
    This was my old one chopped 3'' in front and something like 6.5" in the rear.
  12. xristosk22
    xristosk22
    thank you everybody for all the great feed back and kind comments... i was thinking of a 4"-5" inches cause i had marked the car with 4" tape then stood back and took a picture then cut it out to get an idea and the same with 5". i had liked the 5"... but then again that is on paper. I do like the way that one with the 4" looks... I'm still in the research part but when i do start working on it, I'll make sure to post pictures. thanks again for all the great information.
  13. slddnmatt
    slddnmatt
    5" is a damn heavy chop. I would start 3" and go from there.. The more of a chop, the more fun it is to get gl*** to work also unless you split that roof in half....Im not sure what the regulators look like in your buick but in some all you have to do is rotate the regulators to the new angle and make some guide channels. not as hard as it sounds.
  14. xristosk22
    xristosk22
    yeah im going to start with the 3". thanks for the window pics.
  15. The thing is.....
    on a 5 plus inch chop,you will run out of rear/ C pillar altogether literally and visually....
    BTW more is hardly ever better on chops.
    also you will end up havin to tilt that rear gl*** so hard it will end up raising the rear of gl*** and ends up looking like it has a raised hump between the gl*** opening and trunk lid.
    a sedan as shown above is actually 2" taller than a hardtop of same year so it matters whaich you start with....
