Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. farmer12
    farmer12
    Thanks guys! I think they'll look a lot better and cleaner than the Cad caps. I was surprised I found these in such good condition.....I had been looking around for them for the past few months but couldn't find too many. (some were even made into clocks.....) Can't wait to put them on the car and see what they look like!:D:D:D
  2. SlmLrd
    SlmLrd
    from DAGO
    Yup, they look great. Same ones I'm running on the 40. Easy mounting too!
    Looking great Eric.
  3. Johnnyolds98
    Johnnyolds98
    Wow! Way cool hubcaps you got there!
    Good looking build.
    Rgds,
    Jan
  4. farmer12
    farmer12
    Thank you for the nice words exterminator. It will be on the road next year. Going to use the winter for bodywork/paint. Can't wait to get started on that!
  5. bigrickl74
    bigrickl74
    I put a set of 51 Ply caps on my 48. I think they are a killer cap and your staying true to the Plymouth family. :D
  6. farmer12
    farmer12
    Thank you my friend. Looks like we both have a decent taste.
    Thank you Jan
    I like the fact that they are relatively simple and not distracting from the car as whole, but rather complementing it.
  7. farmer12
    farmer12
    It was time to start re-shaping and fit the new inner panel. I first removed the outer fender in order to get better access, then got my cardboard model into position. After modifying the metal, especially around the suspension area, I managed to get it into position. I left some extra room on the bottom between the wheel and firewall, so some of the heat of the headers can escape.
    On the list for the next time is to create room for the tire when turning, working out a way to attach it to the firewall and the top of the fender, and ensure that there'll be sufficient clearance next to the valve cover. Plenty left to do!
    Good thing is, once this side is completed, the other one will be more or less a copy/paste procedure. (famous last words:D)
  8. hemi v8
    hemi v8
    Good choice of hubcaps! Much better than the previous 57 Cads. Good work on the inner fenders so far, looking great! Inspirational craftmanship as always.
  9. TexasSpeed
    TexasSpeed
    from Texas
    I experience that all too often.. They look good however! Digging the louvers.
  10. farmer12
    farmer12
    Thank you gentlemen. The progress will continue next week as my wife has just turned 40 and it's going to be 3 days of parties this weekend!:D:D:D
  11. Hogman
    Hogman
    from Dallas, TX
    Like the new hubcaps, much better. Good work on the fender, keep it up. Going to be a awesome ride.
  12. farmer12
    farmer12
    Thanks Hogman.
  13. 1959apache
    1959apache
    looking good Eric, keep up the good work. I like the louvers. looks good. you should do the same to the hood! Would you start it already?!?!
  14. kbuhagiar
    kbuhagiar
    Good call - happy wife, happy life! ;)
    BTW - I have been following this thread for a while.
    Your level of craftsmanship is stunning.
    You are a credit to the hobby - thanks for sharing!
  15. farmer12
    farmer12
    Thanks Scott. Louvers in the hood would be cool, but I'd like to keep it "clean". Another thing, the Dutch summers aren't extremely hot, so I expect that cooling won't be a problem. Thanks for the comments.
  16. rockable
    rockable
    Looking great, Eric! I like the hubcaps a lot. As always, your taste and execution are impeccable.
  17. LeadSledMerc
    LeadSledMerc
    Coming along real nice, Eric...I'm impressed, you continue to make great progress!! :cool:
  18. farmer12
    farmer12
    Thank you kbuhagiar. It's a pleasure to be part of this great community!:D
  19. farmer12
    farmer12
    Thanks Rock. I see you're still working on your Chevy, looking good! When are you going to work on your Plymouth again? You were so close to finishing.:D
  20. Finnrodder
    Finnrodder
    from Finland
    Looks good Eric.I think those hubcaps are fine choice too!
  21. rockable
    rockable
    The engine in my 86 pickup took a dump, as as soon as I finished fixing the 54 I had to start working on my truck. I should have it zipped up next weekend and can get back to my Mayflyer!
  22. farmer12
    farmer12
    Thanks Keith. Things are coming together, slowly but surely. Another 6-7 weeks and I'll be able to start the dismantling of the car and get it ready for body/paint.
    Thank you Finn. Hubcaps should be arriving in a week or so. Can't wait.
    Good to hear you're still working hard Rock.
  23. 1959apache
    1959apache
    I am jealous.
    It is looking good so far dude, hell.... I am even getting excited that you are going to get it in paint.
  24. farmer12
    farmer12
    Continued with the driver side inner fender today. First thing I did was bend/hammer the metal nearest the radiator support outwards. This will give a cleaner look inside the engine bay, but at the same time making it harder to remove and install the radiator.
    Next was a test fit and mark the area where the engine head was hitting. Cut out the required area and yes, another test fit. Then fabricated the required piece and welded it. After a bit of grinding, I got it to fit perfectly. Then welded it to the inner fender and cleaned up the welds (until I ran out of discs and Dremel bits).
    Tomorrow more inner fender work.:D
    Car likes this.
  25. Looking good!!!
  26. OahuEli
    OahuEli
    from Hawaii
    Can you get the valve cover off with the inner fenderwell in place?
  27. farmer12
    farmer12
    Thank you Scott. There are still a lot of things to do, but I am also looking forward to the next stage of the build.:D
    Thank you David. It's great to see all the followers of this build thread still have the patience and continue the fantastic support!
  28. 1941Ford_Luke
    1941Ford_Luke
  29. farmer12
    farmer12
    Getting the valve will be a little struggle, but by loosening some of the bolts of the inner fender, it should come off. Hopefully I'll never have to.....
