Projects 1949 Ford F1
Discussion in 'The Hokey Ass Message Board' started by gicknordon, Oct 18, 2012.
  1. gicknordon
    gicknordon
    Just joined the site and thought i would make a build thread for my truck.
    Its a 1949 ford F1 that i got this past summer. It had no engine or transmission and is in rough shape. Im gonna hot rod it. Im gonna put a mustang 2 front suspension under it, and a four link rear with an 8.8 out of a ford explorer. The motor is a 1971 429 out of a ford country squire wagon. This is the only part that im gonna have done by a professional. The plan is to have 400+hp. For the transmission im hung up between a ford top loader four speed or a late model tremec tko. Anyway here are some pictures. I also threw in some pictures of some ideas i have for the paint.
  2. fordf1trucknut
    fordf1trucknut
    Looks like a good start.
    I am not a fan of mustang 2 suspensions in a truck, especially with a 429... have you considered keeping the I-beam? A lot of people have asked me over the years what suspension I have under my f-1 since it rides so nice and I always surprise them by showing them the stock I-beam and leafs.
  3. NEWFISHER
    NEWFISHER
    from Oregon
    Love those trucks! Watching your build.
  4. gicknordon
    gicknordon
    Ive thought about it. I want it to sit fairly low and to get it where i want it i would need a drop beam and lowering springs. When i added all the parts i would need up it ended up being very close to a mustang 2 kit as far as cost goes. I figure that if i go with the mustang now, i wont regret later on not doing it. I wanna get everything done the way i want it first and not have to go back and change things, even though i know ill be doing that by the end of the project. I wanna keep it to a minimum though.
  5. charleyw
    charleyw
    Always nice to see another F-1. Good Luck
  6. need louvers ?
    need louvers ?
    I'll be following along as you work too. But I do have to expand on this thought a bit. Long before I went with a Mustang II under one of thses trucks I would look into the Jag XJ6 front end. The weights of the vehicles match quite closely and they are very common and inexpensive. The install will be quicker and easier too. I have done Mustang II fronts under these trucks before, and the big problem is that they have to be widened, which throws the roll center out of whack and leads to a tail light feeling when driving. Next one I do will be Jag, and there is tons of info here on the H.A.M.B., just do a quick search. Everything else sounds great and I can't wait to see what you come up with.
  7. gicknordon
    gicknordon
    Thanks for the input guys. Ill do some more research.
  8. barrnone50
    barrnone50
    from texas
    The jag front is a good fit for these F-1s . I put one in my 51 its like it was made for it. Lots of info and build threads about them. Good luck on your build.:D
  9. Go with the Tremec, dude. They take serious abuse and you get the extra gear.
  10. gicknordon
    gicknordon
    Got the cab and bed off last weekend. Hope to start on the front suspension this weekend.
  11. Diavolo
    Diavolo
    That is simply the most efficient and completely not over the top way to remove a cab.
  12. BennettFab
    BennettFab
    If you go MII, DO NOT buy a cheap kit, like I did. Buy name brand US made stuff!
    I was looking for an F1 when I found my 57
  13. RHOPPER
    RHOPPER
    Another vote for the jag. I'm using one and I'm very happy with it. Installed in one weekend, bolted in. Much cheaper than a mii kit and gives a great stance.
  14. gicknordon
    gicknordon
    It may have been over the top but it actually was the most efficient. From the frame to the back of the crane truck then down the street and right into the back of a reefer trailer.
  15. gicknordon
    gicknordon
    Well my first attempt at sheet metal work was a success. Its not perfect by any means but i am happy about how it turned out. I pretty much have the fender completely patched and i was planning on blasting it and priming it today but it was too wet out so ill have to wait fo another warm streak. Anyway here are some pictures.
  16. 31Apickup
    31Apickup
    Nice Project, here's some insperation from Tootsietoy.
  17. gicknordon
    gicknordon
    Well ive gotten a lot done since the last time i posted. I got the front and rear suspension pretty much done. I just have to figure out sway bars and mount the shocks in the back. I also picked up a t56 6 speed for the transmission.
  18. 53fordcustom
    53fordcustom
    Love those trucks.!
  19. workhorse_01
    workhorse_01
    from S. Georgia
    Nice, cant wait to see
