Hot Rods LIVE WIRE Gets a transplant PT.2 Goodbye LaSalle..
Discussion in 'The Hokey Ass Message Board' started by Evel, Jun 18, 2012.
  1. SAVAGE
    SAVAGE
    Alliance Vendor
    Can't wait to see it drive again!!!
    it ALIVE!!! A LIVE WIRE!!!!!
  2. snot275
    snot275
    jesus christ thats amazing...
  3. dieselc
    dieselc
    from ohio
    Caddy torque through a manual trans should be too much fun.
  4. titus
    titus
    well.........? any progress?
  5. S.F.
    S.F.
    That is one fancy *** crossmember!
  6. Hank37
    Hank37
    My 37 with the 303 Olds. had a 37 Ford box and I could blow the box apart on any hard launch , tried 50 Merc. gears in 37 box still same results. It wasn't hard to switch boxes but my supply was running out. Then I changed to the Caddy mill i went with a Caddy 3-speed out of a 52 Caddy. No problem on breakage but i didn't like the way it shifted, due to the pin type syncro's. So i switched to a super t-10 close ratio from a GTO. That was the ticket, but later on when i went to a 3.42 rear the close ratio didn't do the job, when you can hit 70 in low gear you know your geared wrong. So i went to a 65 Muncie wide ratio and that solved the problem it's now more streetable.
