Fed pictures required
Discussion in 'The Hokey Ass Message Board' started by mfp-66, Nov 3, 2012.
  1. mfp-66
    mfp-66
    Hi all,
    Thinking of building a FED but not sure on the wheelbase either 150" or 170".
    Looking for pictures from the side of Feds that come within these wheelbases, will have a full length powerglide, so please no pics of shorty glides or clutch only rails
    I'm looking to see if they look in proportion eg. Have a good amount of frame in front of the engine.
    Tried search function but most don't have the side on shot I'm after
    Please put wheelbase with pics
    Thanks in advance
  2. GOATROPER02
    GOATROPER02
    from OHIO
    Here's some different shots and angles......mine is 225" with a shorty glide and using a 12-14" coupler, so that would about the same as a long tail shaft glide.
  3. dreracecar
    dreracecar
    from so-cal
    Full lenth glide takes 39" between motor plate and axle center of a 9".
    Car in pic is 193"
  4. mfp-66
    mfp-66
    dreracecar, thanks for the measurements they will come in handy.
    anyone out there want to show off there FED and help me decide
  5. I built an early sixties style Dragmaster Dart. She's not an exact reproduction but close enough for me. She's shorter than you mentioned at 123". I built a shorty th350 for her using a 4x4 output shaft and my own rear plate.
  6. dreracecar
    dreracecar
    from so-cal
    Now for reference this engine is out 29" on a 150" wb. A desission you have to make is what type of rear end you plan on using. A Chry 8 3/4 is 2 1/2" longer than a Ford 9", so the minimum "out" with the 8 3/4 would be 41 1/2
    One of the first things you should do is order up a SFI spec book as it will guide you to the proper frame design. DO NOT rely on the NHRA rule book alone.
  7. mfp-66
    mfp-66
    i won't be doing the framework. i will be getting a chassis builder to do it so it will be hopefully sorted. but i have to work out what wheelbase i want.
  8. fenderless
    fenderless
    from Norway
    Here is a 150" chassis with a sbc, TH400 normal length, 8 3/4" Mopar rear-end.
    Taildragger&fenderless
  9. mfp-66
    mfp-66
    Fenderless, that's ideal. Do you know what the rear tyre diameter is?
  10. fenderless
    fenderless
    from Norway
    I'll get back to you, as the dragster belongs to a friend:)
    When this picture was taken, I think he had 31"x 10.5W - 15".
  11. DRAGSTER_JOHN
    DRAGSTER_JOHN
    here is mine, 175" shorty glide 8 3/4 mopar, just to give an idea of that config its a 1967 jim davis.
    [​IMG]http://sphotos-a.xx.fbcdn.net/hphotos-snc7/328715_266621486699348_6638183_o.jpg
  12. DRAGSTER_JOHN
    DRAGSTER_JOHN
    other pic didnt show... [​IMG]
  13. mfp-66
    mfp-66
    DRAGSTER_JOHN, the front wheels are they bought or home built? 17"?
  14. dreracecar
    dreracecar
    from so-cal
    Those look like early CRAGARS on Anglia spindles
  15. shoesadigger
    shoesadigger
    from Denver
    190" wheelbase, motor is out 42"
  16. DRAGSTER_JOHN
    DRAGSTER_JOHN
    they are aftermarket, akront mabe, ill have to look again
  17. DRAGSTER_JOHN
    DRAGSTER_JOHN
    they are anglia spindles i know that, i just redid the bearings.. ill look at the make...
