1932 frame diagram. Who would be interested in a full size to scale print?
Discussion in 'The Hokey Ass Message Board' started by Salt Flats Speed Shop, Nov 7, 2012.
  1. So for the full size on paper is 110.00 and in two pieces?
  2. Salt Flats Speed Shop
    from Utah
    They quoted me 55$ for the top view. (Which will be in two pieces)
    And another 55$ for the side and bottom views. (Those are thin enough that they should be able to print the side view on one sheet, and the bottom view on another sheet.) Plus shipping. I'll be getting some shipping tubes that I'll ship them in. A smaller tube will be used to roll the paper around so that it won't want to make any creases. That will be slipped inside is what i'm thinking.
  3. fordcragar
    fordcragar
    from Yakima WA.
    Is there going to be a print made that is 36" wide? If it is dimensioned, it really doesn't have to be to scale, depending on what you are doing with it.
  4. Ricky Bobby
    Ricky Bobby
    Yep, I'll take one..........
  5. Either tells here or pm me on how to get you some money through paypal so I can get my order in.
  6. Salt Flats Speed Shop
    from Utah
    My thought here was to make one full size so it could be directly measured. If you don't want one full size then I'd just grab one from Deuce Daddy Don.
    I'm wanting to make one first so that I know if its going to work. So i'll let you guys know once I have one made. :)
  7.
  8. bhurlin
    bhurlin
    from Texas
    I have a pdf one that is full size that prints on many sheets of 8 1/2 x 11 if you want it let me know at bhurlin@kfxperformance.com
