For you guys using the shifter cable what are you using for gromet / or so called shifter boot to seal around the cable where it p***es through the floor? I am using a B&M cable. Been looking at Oem cables wich come with the gromet. I can not find a listing for just the gromet.
I'm interested in this one as well. Right now I just have a hole the cable p***es through. Not bad this time of year because it lets heat in, but certainly isn't suppose to p*** tech at the track.
You guy's can laugh, but the Gromet ***ortment pack H/F is not all that bad. I have used these before on some high end builds and race cars, I mean they are just grommets. To make one into a Split-Grommet take a pair of ****s, or diaganol cutters if you prefer and cut a 45 degree slice into one side and walla, you have a split grommet.
i just went to the parts shop and found the right size grommet for the hole in floor and cut out the hole for the cable.
If you simply can't bring yourself to use the H/F ***ortment, get a ***ortment from Jeggs or Summit or maybe even NAPA. TR
Remember when measuring for the correct hole to drill, use a set of calipers and measure in the groove on the O.D., this way you don't drill a hole and the whole grommet drops through LOL.
Yea buddy, so for those that may not know, don't use a regular drill bit for the hole, use this...................
There is a problem with using a regular "run of the mill" gromet. A typical gromet is designed to have something go "straight" through. Most shifter cables, especially the B&M and/or Hurst cables, go into the floor at about a 30 degree angle. With that much of an angle you need a boot style piece similar to one found on newer cars with a floor mounted parking brake.
You can get them in different sizes so that the hole is suspended in a larger hole, allowing the difference in angles.
You could also take say a 6" piece of oil or fuel line, slit it length wise and put it around the cable. Now put the cable wrapped in the small section of line through the grommet. A black plastic wire tie on each end to hold the hose in place.
Thanks for everyones input. Definately need what ever I am going to use before making the hole. The one in post 18 is simialar to like a second generation camaro /gm type with an angled hole. I think my hole will be on the curvature/side of the trany hump.
