Projects Early Style RPU Build
Discussion in 'The Hokey Ass Message Board' started by rcassis, Oct 25, 2012.
  1. rcassis
    rcassis
    from Indiana
    Here's a few pictures of a project that's been in the works for a while. Hope to finish it over the winter.
    *Car will be dis***embled soon - will be updating post with work in progress
    *Feedback/Questions appreciated
    28-29 Cab
    4 piece Aluminum Hood
    Narrowed Model A grille shell
    Fabricated frame rails
    5" dropped axle-under slung style front end
    1/4" elliptic rear spring setup
    40 banjo rear end
    30-31 rims
    Fabricated bed
    F-100 steering column (truck)
    Vega box
    Chevy II banger motor
    Power glide transmission
    Many fabricated brackets
  2. gnichols
    gnichols
    from Tampa, FL
    It better be good... I see you gave yourself 5 stars? Gary
  3. 117harv
    117harv
    Gary, there are 68 views, it was probably someone else. Yes can we see some more pics, a side shot maybe?..thanks.
  4. gnichols
    gnichols
    from Tampa, FL
    There I go again, making ***umptions. I didn't know you could post a rating without some sort of text post to accompany it. Sorry. Gary
  5. NortonG
    NortonG
    More pictures in his profile.
    This thing is really cool!
  6. 117harv
    117harv
    Pics from his album....looks cool.
  7. sko_ford
    sko_ford
    Looks like a good start man
  8. Don's Hot Rods
    Don's Hot Rods
    from florida
    I really like the look so far. Nice job. One thing I might mention is that you should consider shortening up that long nut on the bottom of your front spring perch. If you blow a tire the first thing to dig into the pavement will be that nut. Just a suggestion.
    Don
  9. Jeem
    Jeem
    Alliance Vendor
    YEP! It's worthy of 5 stars, it's fukn AWESOME!!
  10. Beau
    Beau
    I think the frame will hit first.
    Very cool build!
  11. Blue One
    Blue One
    from Alberta
    Looks good, can you show me some pictures of the steering arms and where you routed the steering cross link above the wishbones and above the frame rails ?
    Would also like to see behind the rad and how it affected your lower rad hose etc.
  12. rcassis
    rcassis
    from Indiana
    Here are two more pictures of the project. Will be taking more over the weekend and hope to have them uploaded to post sometime next week.
  13. rcassis
    rcassis
    from Indiana
    I was going for a late 40's early 50's look but I didn't want the truck to sit real high. We built a suicide style perch and mounted it on the back side of the front crossmember, behind the radiator making the front spring and tie rod run thru the hood sides behind radiator on top of the frame rails we C notched the top of the frame rails. More pictures soon! Lower radiator hose picture will be tough to get right now but will get you one - it's gonna be tight.
  14. Moonequipt13
    Moonequipt13
    Pardon my ignorance, does RPU stand for rod pickup?
  15. HOTRODPRIMER
    HOTRODPRIMER
    Roadster Pickup. HRP
  16. Moonequipt13
    Moonequipt13
    Awesome, thank you! It's taken me a bit to figure out some of the acronyms on the site:D
  17. robber
    robber
    Great project! ;) Very cool! :cool: I like! :) ... what is going to live up front between the frame rails? ...robber
  18. rcassis
    rcassis
    from Indiana
    More pictures and more to come........
  19. rcassis
    rcassis
    from Indiana
    last batch for now....will keep taking more as more progress takes place. Don't hesitate to ask to see something specific. Thank you for all your respected comments and questions.
  20. rcassis
    rcassis
    from Indiana
    last batch for now
  21. tobyflh
    tobyflh
    from Peru il
    really love this build
  22. rcassis
    rcassis
    from Indiana
    any color ideas
  23. 117harv
    117harv
    Washington blue or a dark smoke grey with black accents.
  24. Gasser Junkie
    Gasser Junkie
    Really diggin' it. It's looking fantastic!
  25. OoltewahSpeedShop
    OoltewahSpeedShop
  26. iammarvin
    iammarvin
    from Tulare, Ca
    Jam nuts on the tie rod?
    Love me some rpu.
  27. rcassis
    rcassis
    from Indiana
    in a few of the build photos things like no jam nuts on tie rod and long nut on spring perch are there or not for build up only thanks
  28. rcassis
    rcassis
    from Indiana
    Here are a few shots of the bed. Fabricated work is done & ready for color. Used 32 Ford stake pockets (modified) and the rest of the bed we made.
    1. Model T gas tank with fill neck & level indicator from a military gas tank
    2. Friction shock arms used for taillight mounting brackets. Reworked landscape lights for taillights.
    3. Flat stock with oak strips for bed ribs.
    4. Ford script removed from 40's tailgate, narrowed & riveted to fabricated tailgate.
    5. I can't remember where the bullet shaped hinge came from but we added flat stock to them for tailgate hinges.
    We'll keep pluggin' away!
  29. rcassis
    rcassis
    from Indiana
    looking for thumb screw type radiator clamps
  30. HOTRODPRIMER
    HOTRODPRIMER
    I really like the tailgate. HRP
