lets see pictures of the model A's you are working on ...
Discussion in 'The Hokey Ass Message Board' started by lorodz, Oct 14, 2010.
  1. don daddyo
    don daddyo
  2. MO A-Rod
    MO A-Rod
    from Missouri
    Here's my recently finished "mostly model A". :)
    '30 A: tudor frame/cowl/doors, radiator surround and '28/29 A enclosed cab pickup rear cab.
    '47 Sedan axles.
  3. amsgd
    amsgd
    from England
    Here is mine.
    Added Buick drums and Tri carbs since these photos.
    Hopefully finished for next year.
    Graham
  4. jimbob
    jimbob
    Mine, getting closer.....
  5. Rods & Relics
    Rods & Relics
  6. Slimegreeeeeen
    Slimegreeeeeen
    Slowly but surely...
  7. novatattoo
    novatattoo
    from Canton,OH
    So many bad *** model A's in the works...........
  8. thewishartkid
    thewishartkid
    Now something totally different.
  9. thewishartkid
    thewishartkid
  10. 210sedan
    210sedan
    from upnorth,wi
    yeah lookin good Jimbob
  11. Rusty Cheese
    Rusty Cheese
  12. GaryC.
    GaryC.
    What I'm starting with and how I want to finish.
  13. 500 single
    500 single
    ImageUploadedByTJJ1352838913.812947.jpg ImageUploadedByTJJ1352838932.341544.jpg
    Here's my 31.
  14. Model A Gomez
    Model A Gomez
    Mocked up my 30 Sport Coupe about four years ago and then started a 60 T-Bird mild custom, the coupe was buried under parts. Finished the T-Bird and started back on the A, stripped back to the bare frame, finished all the welding and cleaning everything up for rebuild and paint. Has 8BA flathead, 39 trans, 51 F1 steering, 40 brakes, hope to finish it in the spring. My avatar is a 28 coupe I built in the early 90's with a V8 60 flathead and have a 30 pickup with an inserted four for an every day driver.
  15. 17dracing
    17dracing
    from Indiana
    Here is my newest one . 1929 Model A coupe , with a salt flat twist !!
  16. martyndj
    martyndj
  17. dogpatch customs
    dogpatch customs
    from ohio
    WELL KINDA.... home made metal body,modeled closely after a 29, with a slight twist on the body lines.
    60's frame.
    Desoto drive line.
    split bones.
    planning on running just the hood top.
    george
  18. Grudge
    Grudge
    Here's mine
    And some inspiration for my build
    Aaron
  19. lorodz
    lorodz
    Wow this lil pick up is sweet
    Sent from my DROID device using the TJJ mobile app
  20. Wardog
    Wardog
    Needed a bit of help on the coupe today.
  21. Wardog
    Wardog
    Second try.
  22. flatout51
    flatout51
    Just another AV8 sedan...
  23. 74bowtie
    74bowtie
    Progress is slow but here is where I am at with the 29 roadster pickup.
  24. hillbilly4008
    hillbilly4008
    from Rome NY
    74bowtie, you gonna have that in 'Cuse this summer?
    here is my Av8 "tub" started as a 28-29 Special Coupe, then I grafted on a '26 Buick sedan rear.
  25. 74bowtie
    74bowtie
    I am going to try, working the rearend install at the moment haveing to change the rear frame again. Is that the car you will have there this year?
  26. hillbilly4008
    hillbilly4008
    from Rome NY
    Not a chance. I'll be bringing my '53 DeSoto
  27. hillbilly4008
    hillbilly4008
    from Rome NY
    Just rolled it outside for the first time!
  28. T__N__A
    T__N__A
    banger in the works.....
  29. Harvey29
    Harvey29
    from kansas
    Getting closer
