24stud 59A (Underground)
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Nov 13, 2012.
  1. 340HilbornDuster
    340HilbornDuster
    Do you guys think it's possible/worth it to revive this engine.
    It's in a pretty dry area (for Hawaii)...the earth might have preserved it...?
    Intake and water returns have been open all the time.
    Mahalo
    Tommy
  2. timwhit
    timwhit
    tear it apart and see how it looks.....put it back together and see if it will run
  3. Might. The casting, if not cracked or bored to the max, hmmn. I guess the main bearing bores and cam and lifter bores are critical.
  4. belyea_david
    belyea_david
    from Regina, SK
    No frost cracks if it's spent it's entire life in Hawaii!
  5. Looks like that thing is extremely rusty.Some of the head studs and bolts are wasted as is the water outlet on the head.I'm geuessing IF you get it apart it will be pretty thin.I've seen plenty of stuff fixed but I'm betting that one is done.
  6. 340HilbornDuster
    340HilbornDuster
    Definetely no frost!
    I bet it was placed there ABOVE ground, and TIME dug it down...
    It must have been there for a loooong time.
    T
  7. zgears
    zgears
    It could be fine. If its pitied bore it out.
  8. captainjunk#2
    captainjunk#2
    if it was free or really cheap , id score it and take it apart just for looks
  9. 340HilbornDuster
    340HilbornDuster
    He wants 50 bucks as it sits.
    Maybe I'll bring it home and If it's toast.
    - I'll dig it down in my own yard...Wifey would love it...NOT!
    T
  10. stillrunners
    stillrunners
    from dallas
    are flatheads kinda rare over on the island....not sure how y'all s**** stuff....
  11. dragsled
    dragsled
    from Panama IA
    For 50 bucks I'd take a shot, Like you said if it junk use it to piss off the wife:D,,, BTW my older Brother raced a duster when I was a kid thats what got me hooked on this Drag raceing ****:) Tim Jones
  12. There is a far worse one than that in the tidal portion of the river where I walk the dog. It was awesome when the tide was out and I found a flathead on the beach. I am spending enough on machine work doing a flathead that ran and has a nice block, can't imagine starting with something that was rough or REALLY rough.
  13. deucemac
    deucemac
    I would be very surprised if the block is salvagable since it is sitting upright and the intake is uncovered. I just pulled one down that was here in the desert of SoCal for years in the same position and it needed all 8 sleeves and had pitting in the port transfer area. It was a 59L block and the customer wanted to use it but what a mess. If is has been sitting for a while in Hawaii with all the rain and moisture there is, I wish you good luck!
  14. Bruce Lancaster
    Bruce Lancaster
    Well, remember that cylinders will take a very large overbore and that valve seats are readily replaceable. The only certain death situation is freezing, and I guess you are home free on that! If you can get the thing torn apart...likely you can rebuild. Starting with a better one would be much more...sane, I guess...but this is the HAMB, and saving a lump like that would have major cool value!
  15. 40FordGuy
    40FordGuy
    Give him the $50 !!!!!!! I bet there's that much in useable parts.
    4TTRUK
  16. Bruce Lancaster
    Bruce Lancaster
    Oddly, the little potmetal fitting on the manifold for vacuum hookup is a rare and rather pricey piece...most are broken. This one proves the engine has not been rolled over during its dormancy!
  17. Torchie
    Torchie
    I am taking one apart right now that was mostly buried on it's side. Most likely it sank into the ground from sitting. Biggest problem so far is getting the exposed head off. That ****er is realy stuck on there. Side that was buried came right off. Plus no signs of cracks so far. Got it for free and may end up with a good block.
  18. 1952henry
    1952henry
    Try for less. As stated, might have some useable parts at the least.
  19. 340HilbornDuster
    340HilbornDuster
    How much would a mild rebuilt (sleved) running 59A go for?
    (To put it in perspective!)
    I have a couple of hours of work getting it out of there
    & I have to feed my Brother in Law ... Where at $100 bucks allready!)
    T
  20. zgears
    zgears
    Can you pull the heads were it sits?
  21. 340HilbornDuster
    340HilbornDuster
    I can get to the head on one side...
    I'm not sure the studs will budge though!...they lookl kinda rusted.
    T
