What is the worst thing you have seen done on a build?
Discussion in 'The Hokey Ass Message Board' started by Edsel58a, Nov 13, 2012.
  1. Edsel58a
    Edsel58a
    This one for me is easy, I looked at a 54 Ford truck once that had a Mustang II suspension in it. To get the column and rack joined, the builder (not sure if seller built) welded a Craftsman 1/2" drive swivel at the base of the column an extension with the spline welded to it!!!!!!!!!
    Wish I had a pic of it.
    No, I did not buy it
  2. Andy
    Andy
    I saw a car where the builder shortened a pinto cable steering shaft by cutting it off and putting the end in a piece of pipe and putting a bolt thru the cable and pipe. I also worked on a car built at a pro shop that had rounded off all the splines on a Vega box steering shaft and put on a U-joint and just used the two set screws.
  3. charlieb66
    charlieb66
    Looked at a car a few years ago, no front sheet metal. The front suspension was real weird for a street rod. Asked the owner wht it was, he answered that it was from some mid sized Cadalic, and it was installed backwards. I questioned how did he connect the steering, he opened the p***enger door and there was the steering wheel on the right side.
    Later heard that once he got it running he couldn't drive it and replaced it with a MII.
  4. ParkinsonSpeed
    ParkinsonSpeed
    I saw a guy weld a frame up with a 110 welder with flux core set on the low setting... Then spent an hour grinding the welds off for a super clean look with no gussets. I hope he doesn't put his life into his own hands because he sure wasn't going to listen to me about it.
  5. outlaw256
    outlaw256
    ^^^^ you better hope he dont put YOUR LIFE in his hands.like drivin on the same road and at the same time as you!!! or anyone else for that matter...
  6. themoose
    themoose
    A 53 Chevy with a small block that had the motor mounts brazed to the inside frame rails.
  7. afaulk
    afaulk
    A guy that I know took his drag car to the local track and when he unloaded it off the trailer the entire front suspension fell off. He had a hell of a time getting it back on the trailer.
  8. GREASER815
    GREASER815
    A guy that bulit a frame for his roadster out of pallet racking.....
  9. Chaz
    Chaz
    I once saw a 32 Ford that didnt have a small block Chevy in it.
  10. teejay99
    teejay99
    Geez Chaz , that's a rarity ...wish you had a pic , I've never seen that before !
    T
  11. Edsel58a
    Edsel58a
    what?
  12. 117harv
    117harv
  13. HOTRODPRIMER
    HOTRODPRIMER
    Man,I had one of those.:D HRP
  14. 100dollardodge
    100dollardodge
    I have seen more than a few street rods with "street glow" under them. You know those fast and furious lights under the car? might as well have euro tail lights and those bumble bee exhausts.
  15. VoodooTwin
    VoodooTwin
    from Noo Yawk
    x100000000000000.
  16. 49ratfink
    49ratfink
    here's some steering I redid on a 1940 Ford Pickup.... in the second picture I was under the car looking up. the red you see is the firewall. also notice the boxing plate in the frame is no longer welded
  17. CodeMonkey
    CodeMonkey
    from Moline IL
    A bit left of field: back in the early 80's I remember seeing a pinto hatchback converted into a 4WD, including 32" tall tires. They used 4x4's (the kind that come from trees) for the font subframe. I didn't get close enough to see what else was cobbled together.
  18. 49ratfink
    49ratfink
    fixed it with the parts below. also check out the axle pads. they are about 1.5" wide. one good burnout would probably twist the rear end out of the u-bolts. I didn't fix that, he wanted the truck back.:confused:
  19. propwash
    propwash
    from Las Vegas
    47 Ford coupe with a 371/hydro in it. X-member removed and the frame was strengthened with pieces of channel that were C-clamped to the rails and then the clamps were welded in place, the trans crossmember/support/mount was similar material fastened in the same way. Needless to say, I trailered it home even though the seller told me he drove it all over like that.
  20. 31Apickup
    31Apickup
    When I got my Model A mostly in pieces back in 1975, the frame was a hacked roller. This was the front axle, an econoline that they cut the parallel leaf pads off and then welded some round stock in I-beam recess and drilled the spring perch holes for a stock model A spring. I thought this was s****ped years ago, but came across it in the back attic of my Dad's garage.
  21. 49ratfink
    49ratfink
    had a 49 Chevy sedan with the motor/trans at 3 degrees down, and the rear pinion was 4 degrees down. same car had about a foot of the trans crossmember cut out and a piece of 1 x 1 angle iron was bolted in to hold up the transmission.
    one more great thing the previous owner did was put in rear dump exhaust manifolds on the 350. well with the underfloor brake pedal the brake arm came down and hit the manifold before the master cylinder went through its full travel. the brakes were **** and the guy just kept driving, he even told me after he put the V8 in, the brakes stopped working well. best part? he was a mechanic at a dealership. guess there is no computer code for "brake arm hitting the exhaust manifold dumb***."
  22. THE_DUDE
    THE_DUDE
  23. CanUFelix
    CanUFelix
    from venice CA
    im sure there's a lot worse but here's two of the many ***hat things the previous owner did to my roadster. gradually working through righting the wrongs....and there are MANY!!!
    throttle pedal held into toe board with washers and staples
    Gas tank held in place with blue foam and rubbing up against rough angle iron behind the seat.
    Genius....this guy calls himself a serious builder and sneers at rat rodders. its what you get when you buy sight unseen. I'll never learn.
  24. 500 single
    500 single
    A lot of the stuff I see on here makes me kinda self-consious about my own work, and inspires me to try harder.
    But not these:)
  25. Johnnyboy69
    Johnnyboy69
    from Pomona, CA
    Crooked frame was the worst thing I saw on a 34' ford. It just didn't look straight and the guy said it was 100% perfect. That's Pomona Swap Meet for you :/
  26. Metal Mangler
    Metal Mangler
    from Washington
    Anyone that builds a car with any part of the steering or frame below the scrub line. People always say oh its no big deal...its isnt until you get a flat or a blowout at freeway speed.
    Matt
  27. Mr48chev
    A lot of what the guys showed was more common than one would think in the 70's and early 80's.
    I was re-torquing the head on my 48 close by the Michigan Hot Rod repair tent at the 73 Street rod Nationals in Tulsa when they drug in a rod that had broken down in town that had 1/2 in electrical conduit with the ends hammered flat bolted on for a four bar style radius rod setup with 5/16 or 3/8 bolts to hold them to the axle and frame. The owner had actually driven it several hundred miles that way.
    Steering wise, I believe this came from an earlier thread on the same subject.
  28. 67coronet
    67coronet
    Bought a 55 Chevy with a new 283 and 3 on the tree. Was told it had air shocks on back. Drove two blocks and almost wrecked it! Looked under rear and it had muffler clamps on the shocks! That was in 1978. Still have the car but now has coil overs under him.
  29. BIG-JIM
    BIG-JIM
    from CT
    The motor mounts on my 34 Tudor were paper thin and ****** welded on. As an extra added bonus he (the previous owner) used a washer as a steering support.
    Third picture of me cutting them out.
  30. blue 49
    blue 49
    from Iowa
    I happen to have built my frame from pallet rack crossmembers and I don't see a problem with it. I've got 15,000 miles on it so far.
    Blue
