32-34 pickup pics?
Discussion in 'The Hokey Ass Message Board' started by wes, Oct 6, 2003.
  1. 35fordcoupe
    35fordcoupe
    from Virginia
    How much is that chop?
  2. jevans612
    jevans612
    Here is my first attempt at a 34pu. The red/blk - 'Lil Red' is my daily driver.
  3. acme30
    acme30
    from Australia
    Hi sorry for the delay in reply I don't have the exact measurement but I can tell you how I worked it out. (Edit Feb 2021 - 2 and 1/4 inch chop, was supposed to be 2" but I had to take a bit more out due to error on my part)
    I personally don't like the radical chops and wanted this one to look like it was stock to the untrained eye but would reduce the size of the stock door window opening - which to me seams out of proportion with the rest of the body.
    The way I worked it out was I actually chopped the doors first.
    You will see the 30 coupe in the background - I figured if I made the door window height the same in the pickup as it was in the stock height coupe than if it looked ok in the coupe it would be ok in the pickup :)
    The door window opening height (hole height in the door) is 13.5 inches so that is what I made it on the pickup.
    Pretty sure I have read it on here somewhere (might be in this thread) is that an easy way to chop the top of the windscreen posts is to unpic the header bar, chop the top off (not in the middle of the posts) and then refit the header bar. This way you don't touch or disturb the hinges.
    Also much easier to chop the doors above the hinge post and that keeps it all pretty simple.
    For round the back of the cab I made it a bit harder becasuse I sliced some out from below the window and also cut some out from above the window. The bit above the window isn't so bad though becase you can just bend over another top edge. Not much welding required that way [​IMG]
  4. acme30
    acme30
    from Australia
    Sorry for the delay in reply I need to work out how to use the thread tools better :mad:
    Here is an early pic of the blower set up
    Blower is a GM453, manifold is a 2 carb Luberg (Australian) machined flat with a custom plate to the blower - BDS blow off valve fitted to front of adaptor and pressure relief valve fitted to snout. Carb adaptors - custom machined as is the rear cover plate. Carbs are blower referenced 94's by Neville Anderson
    Blower snout is a modified M90 from a V6 Commadore. Oiling of blower is via main oil feed from block (oil feed and return lines not run yet - oil goes in the side of the blower and drains back to block via internal lines in adaptor plate -then back into block in front of oil breather).
    Custom pullies - tension on belt is via alternator - hoping to get away with 1 v belt but if it slips will chnge to 2 belts.
    All machine work done by 34 pickup - thanks Phil
    31hotrodguy and Hotrodmyk like this.
  5. waine
    waine
    Theres still one more out there,this is my 34 with a extra long bed.Traded or it last Sept. and I am having a ball working and driving it.
  6. triumph 1
    triumph 1
    Looks like an old thread? Anyway............. here's my 32
    31hotrodguy, Gsquires and waxhead like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Yes it is ,,,,a "OLDIE but a GOODIE"!:D
    It's one of my on going favorite threads! HRP
    31hotrodguy likes this.
  8. 32Tudor396
    32Tudor396
    My early christmas present....believe it or not,early farmer hotrodding.Deuce cab on a 29 gmc frame:eek:.He didn't even know what it was.;):D:rolleyes:
  9. DANA RED
    DANA RED
    Like that Hiboy truck
  10. triumph 1
    triumph 1
    Thanks! I appreciate that.
  11. VoodooTwin
    VoodooTwin
    from Noo Yawk
  12. brian aldridge
    brian aldridge
    My 34 pickup with a J2 Olds and a Packard ****** with R11 overdrive
    [​IMG][​IMG]
  13. Hotrodmyk
    Hotrodmyk
    Here's my '34 still working on it.
      416.5 KB
      376 KB
      322.8 KB
  14. ^^^ Looks nice, and done to me!
  15. Hotrodmyk
    Hotrodmyk
    Thanks Man, still doing a little body work (hood id a little rough) and some small stuff underneath.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Perfect Stance
  17. brian aldridge
    brian aldridge
    Feel free to sketch it up...
  18. DANA RED
    DANA RED
    Its been a while, finally got some painting done.:)
  19. DANA RED
    DANA RED
    After mockup, now all apart.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Looks great Henry,,what color are you going to paint the truck? HRP
  21. DANA RED
    DANA RED
    :)DANNY, sorry for the delay, been waiting for better weather to finally get the frame painted. YES it is RED.
  22. jammersspeed
    jammersspeed
    from herman mn.
    here is a 34 i picked up a few months ago...
  23. Bought this '33 last week.
  24. austinhunt
    austinhunt
    That's a sweet find Flowmeister!
  25. A Boner
    A Boner
    image.jpg Nice one.
  26. A Boner
    A Boner
    image.jpg Slick long box.
  27. A Boner
    A Boner
    =====picture no longer available=====
  28. Saw this '33 at Spokane GG's a few years back.
    Not sure who owned it, but I really liked it.
  29. DANA RED
    DANA RED
    Some more progress this past week
  30. MannyK
    MannyK
    from NYC
