weird sticky film inside my windows...
Discussion in 'The Hokey Ass Message Board' started by alteredpilot, Aug 28, 2005.
  1. anyone else??
    after a while, i get this sticky nasty film that builds up in a funky pattern on the inside of the windows of my 60 chevy. its kinda brown and smells funky. i usually s****e it off with a razorblade. any idea what it is??
    i dont smoke so that aint it. the car is outside almost always...
    anyone, anyone??
  2. krooser
    krooser
    That's usually the plastic "out-g***ing"...it releases chemicals into the air that stick on the window...always had that on my 50/60's cars....
  3. Too many flippers....
    JOE:cool:
  4. Missing Link
    Missing Link
    Quite possibly oil film from the engine bay. Unplugged holes in a firewall will most definately have this effect.
  5. Bugman
    Bugman
    I was gonna say that:D
  6. After a night at the "submarine races" I used to leave the windows cracked so the smell went away... then dose everything with windex togive it a good sterilization... that should do it...
    Sam.
  7. Sport N Woode
    Sport N Woode
    from Middle TN
    I'd lay off the Mexican food for a while........might clear up!;)
  8. fastfrankie73
    fastfrankie73
    you might want to rethink your p***enger for the " sub races" :eek: :p
  9. 34Fordtk
    34Fordtk
    Roflmfao!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  10. DrJ
    DrJ
    That usually goes away after a couple years, though...About when the vinyl is all dried out and starts cracking.
    This might still be true if the car's been reupholstered in "original" type materials but I'd also suspect a leaking heater core...
    Funky smell mentioned? leaking heater core fluid on a carpet backing will give off an odor that's best described as smelling like the trash can in a ladies rest room on a hot day...
    (No, don't go around sniffing them, just worked in enough "entry level" restaurant jobs to have been stuck with emptying them.) :(
  11. coupla48s
    coupla48s
    A leaking heater core will leave a greasy film on the inside windows.....
    Kevin in Seattle
  12. heater core has been dry and capped as long as i've owned the car. no gaping holes in the firewall. car was repholstered in vinyl and velour.
    i took the back seat out a long time ago. maybe gas vapor particulates coming thru the trunk??
    flippers??
    i must be gay. went right over my head.
  13. gregga
    gregga
    When I was a pup in the 60's, my summer job was reconditioning cars at the local GM dealership. We mixed up the GM windshield washer concentrate and ammonia to get that stuff off. It was worse in a smoker's car, kind of gummy. But they all had it.
  14. Oh man... I wish you knew how funny that was...:D
    Now it sounds like you need Windex AND upholstry cleaner...:rolleyes:
    The origin of "the flipper"...
    http://www.jalopyjournal.com/forum/showthread.php?t=68249
    Nothin' personal, it's just so ****in' funny... :D :D :D
    JOE:cool:
  15. Yeah, it's the vinyl and foam from the upholstery job 'out-g***ing' - that is bleeding off chemicals and plasticizers. It'll eventually go away, but by then the vinyl's dried out and needs to be replaced.
    When heat builds up in the car, the gas comes out. Sorta like my colon after too much Frank's Red Hot sauce on my red beans and rice. :eek:
  16. flipper.....got it.
    gay, right over my head....got it.
    (note to self: read EVERY post so as not to leave self wide open)
    anyway, the g***ing out thing makes sense. my car sits in the sun a good part of the day. the sticky icky has been less since i started leaving the windows half open....
  17. 64Belair
    64Belair
    from Milford PA
    I had that on my 64 belair windows too, its from leaving the windows closed in the heat, damm these old chevys cook inside! i couldnt even see thru the windshield in mine.
  18. jazzbum
    jazzbum
    plasticizers, baby! my 69 chrysler had that problem real bad. try cl*** stripper (nothing too harsh).
  19. jazzbum
    jazzbum
    i meant gl*** stripper. cl*** stripper is better though.
  20. Psycho78
    Psycho78
    from EXP, CA
    Yeah I've got that on my 60 chevy. Haven't noticed if it's sticky. Mines more like stains that wont come out. No matter how much I clean the gl***, **** just doesnt go away. I've gotta check to see if it's filmy.....bugs the **** outta me!!!
