Replacing wood in a 35 GM
Discussion in 'The Hokey Ass Message Board' started by oldspert, Nov 11, 2012.
  1. oldspert
    oldspert
    from Texas
    How much trouble is it to replace the wood structure in a 35 GM two door? Especially the wood around the doors.
    Ed
  2. kennkat
    kennkat
    If you are a cabinet maker, used to working with hard woods I would say no problem to make your own... If not I would suggest buying a "wood kit" if one is made for your car...
  3. scotts52
    scotts52
  4. oldspert
    oldspert
    from Texas
    I get no response from this e-mail.
  5. scotts52
    scotts52
    I think it took him maybe about 2 weeks to get back to me. I was told he is a bit slow to respond. I guess they were right.
  6. flatmotor40
    flatmotor40
    from georgia
    where is he located
  7. grapp
    grapp
    I've done them before, If you have decent enough patterns with the old wood it's fairly easy, you will need a band saw, a drill, (or a drill press is better) Sometimes the more complex curved parts were finger jointed with like 1 1/2 finger joints. You'll have to glue up several layers and stagger the joints on those pieces. A jigsaw and a table saw may be needed too. It's time consuming with lots of test fitting but worth it. Use Ash wood which is HARD as a rock, or use Oak which is easier to find. Post pictures!
  8. TFoch
    TFoch
  9. flatmotor40
    flatmotor40
    from georgia
    Thanks as I have a 35 2dr standard that I need some wood for
