Projects Carter's 29 Roadster Build Thread
Discussion in 'Traditional Hot Rods' started by Carter, Mar 12, 2012.
  1. Crackett
    Crackett
    What size rivets did you use on the body? Sweet looking car man
    Wanted: 28-29 Model a Roadster Quarter Panels
  2. Carter
    Carter
    I bought several of the floor pan rivet kits from Snyder's. They are 3/16 rivets in various lengths. I found I needed more of the longer ones that what was included in the kit.
    Dave
  3. Flop
    Flop
    looking goood!!
  4. bp1971
    bp1971
    from Fresno, CA
  5. Carter
    Carter
    Finally got my engine back today. Went and picked it up this morning.
    Have some fasteners to swap out as he used stainless head bolts and side cover bolts.
    I had the head done in yellow as it is a 6:1 Winfield yellow head.
    It's very bright.
    Sent from my DROID device using the TJJ mobile app
    Bigcheese327 likes this.
  6. Carter
    Carter
    .080 over, Stipe .330 cam, lightened flywheel and V8 clutch, etc.
  7. MN Stumpjumper
    MN Stumpjumper
    Looks Good, Get That thing fired up!
  8. Carter
    Carter
    He still had it on the run stand when I got there, so I did get to hear it run this morning. Can't wait to get the Winfield intake and carb on it and get it in the car.
  9. onekoolkat1950
    onekoolkat1950
  10. chevydave1965
    chevydave1965
    from Iowa
  11. general gow
    general gow
    MODERATOR
    awesome little motor!
  12. Carter
    Carter
    Thanks, Mark. Should move my roadster along pretty well, I hope.
  13. general gow
    general gow
    MODERATOR
    you'll kick my **** in the Silver City at the next RoG, that's for sure.
  14. Crackett
    Crackett
    You wouldnt have the measurements for where the bolt holes in the sub rails go. I brought snyders sub rails and want to be bang on with where i marked the holes before i drill.
  15. Carter
    Carter
    Which bolt hole locations do you need? I can get them for you.
  16. Crackett
    Crackett
    I forgot to mention its for where the cowl posts mount
  17. Carter
    Carter
    The A pillars mount to the subrail using rivets. Do you need rivet hole locations?
    Check this thread out also.
    Dave
  18. 26 T Ford RPU
    26 T Ford RPU
    I used to love 32s but 28-29s now seem much nicer and yours is a good example why that is. Very cool. JW :)
  19. Cali4niaCruiser
    Cali4niaCruiser
    Neat car, subscribed! I didn't even know there was an "inner trunk panel" until I saw you car, lol. Lots to learn here. Can't wait to see it finished up!
  20. Clutched
    Clutched
    This is a great thread. Nice work, and fantastic detail!
    Im excited to see it with those laid back stanchions on there!
  21. Ghost of ElMirage
    Ghost of ElMirage
    How the helled I miss this build thread? Subscribed !
  22. Carter
    Carter
    Thanks, Geoff.
    Hope to have some updates soon.
  23. Chucky
    Chucky
    Geoff's not the only one "watching". My build strays from traditional, yours is spot on.
  24. Crackett
    Crackett
    I'm after the measurements for drilling the two holes that mount the body to the ch***is if that makes sense. Snyders rails come undrilled Thanks
  25. Carter
    Carter
    It's been a long time since I've had anything to report. I've not done much since December. My dad bought a 40 sedan over the holidays and we went up to Michigan and picked it up after Christmas. He left it here for me to check over and get the mechanicals sorted, so I've been working on it a little, but really I just had no motivation this winter. Well this weekend was decent here, so I decided it was time to make some more progress.
    Yesterday I swapped my new engine in.
  26. Carter
    Carter
  27. Carter
    Carter
    Today I mounted my battery box, installed my Winfield intake/carb, Mallory distributor and finished up all of the other little things like spark plugs, fuel lines, etc. Tomorrow I should have battery cables run and floorboards bolted back down.
  28. Good to see you back on it!
  29. Just Jones
    Just Jones
    Excellent thread. This exemplifies why I love The HAMB. Such a beautiful, understated, and unique build. Thanks for posting, and please keep the updates coming.
    Subscribed.
  30. SUHRsc
    SUHRsc
    Glad to see some progress....
    Will we see this ****er in my area this spring?
