Would you guys consider putting a 4 cylinder in your ride?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Sep 7, 2011.
  1. BabbitBeater
    BabbitBeater
    from Colorado
    I saw a BT4 ***mins setup in a 68 Ford Truck and it turned out pretty good. Had plenty of torque, but was not a high RPM motor. Did not go real fast down the interstate...
  2. Jay Tyrrell
    Jay Tyrrell
  3. joedoh
    joedoh
    from Wichita KS
  4. ss34coupe
    ss34coupe
    That looks like a slick installation.
  5. Apittslife
    Apittslife
    Yes I would consider it.
    The modern 4cyl. has stock HP outputs that are equal to & exceed V-8 HP outputs from the mid 80's. so I would have no qualms to use one.
    Infact I am considering the ***mins 4bt, for my build. but honestly am more inclined to go with the 6bt do to cost between the two.
  6. rcavaliers
    rcavaliers
    from downey
    If anybody replaces flatties with 4 bangers ..... I'll gladly take'en off your hands. Or any V8 for that matter :rolleyes:
  7. Offenhauser and Miller seemed to have pretty good luck with 4 "bangers"
  8. ramzoom
    ramzoom
  9. Nitro Breath
    Nitro Breath
    from Eugene, OR
    I owned a Model A pickup with a turbocharged 2.3 Ford and, although it was reasonably peppy, it really lacked the hot rod sound. After that, I'd rather have an anemic 8 than a fast 4.
    Good luck!
  10. tlmartin84
    tlmartin84
    from WV
    I haven't posted on here in awhile as I decided to go the straight six route.
    However, I drove my sisters new 2.0 L ecoboost ford escape (3500 lbs). That thing was WICKED. Granted it revs high, but it revs fast and will set you back in your seat if you want to get on it! It has way more pep than our 3.7 jeep liberty and my 5.4L f150 and 4.7L dakota. Granted they are heavier but the seat of the pants felt really good.
    If a turbo 2.3L can get close to that ecoboost, I for one would not have any reservations about putting one in a vehicle I am building (under 3500 lbs), especially for a daily driver. 27 mpg to boot, go figure....
  11. Just got a Thomas head for my banger that's going in my 27 coupe!!! Zephyr two pot set up and a wild double pipe st up!!! Should be somethin wicked!!!
  12. lilbdfrd
    lilbdfrd
    There is a guy who built a 4 banger on the 460.com forum for his stock car . That used misc. parts from a 460 ford. I think it made great power but not sure on mileage.
  13. gnichols
    gnichols
    from Tampa, FL
    Sure, but my vote now is for the 2.0 Turbo Ecotec Chevy / GM motor as I supect the new Fords won't be available cheap / take-out for some time in versions that can be fit with inline drives. Gary
  14. gimpyshotrods
    gimpyshotrods
    Not a 4-cylinder, but my Falcon has a m***ive 144-inch engine in it. It drives just fine.
  15. Leon Sandcastle
    Leon Sandcastle
    ImageUploadedByTJJ1362256238.324677.jpg 54 lotus/ford 4cylinder.
  16. handmedown40limited
    handmedown40limited
    from tracy ca
    yes I have been considering one. A ***mins 4. Would be an interesting match for my 40 buick
  17. leon renaud
    leon renaud
    from N.E. Ct.
    I believe the 2.3 measures out to 140 C.I.
  18. rd4pin
    rd4pin
    from louisiana
    Yes I considered it, but installed a V8 Ford instead.
  19. gimpyshotrods
    gimpyshotrods
    Good thing it is a 2.4 then! 1.75 x 1.75 x 3.1416 x 2.5 x 6 = 144.31725. Never mind that mine is 0.020" over.
  20. This pickup with the Pinto motor is killer. I would love to have this truck.
  21. black 62
    black 62
    from arkansas
  22. c-10 simplex
    c-10 simplex
  23. oakhill
    oakhill
    Nope - no way
  24. hotroddon
    hotroddon
    Not only would I consider it, I just did it
  25. hotroddon
    hotroddon
    Just so you know - Ford sued and won, stopping that truck from being built. Second, it was acknowledged that the 104 HP, 177 ft lb diesel was not powerful enough for a full size truck, even for a developing auto market like China
  26. jazz1
    jazz1
    I would, only got 6 right now,my IHC weighs less than my toyota xtended cab 4x4 which works pretty good with only a 4 cylinder..my son inlaw put a Powerworks TM supercharger in his 02 ford focus,,340hp and boost could be increased...ran like a ****d ape!
  27. pitman
    pitman
    Lookin' good Don! Nice build.
  28. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    OOOOHHH! Side draft Webers! The more the merrier! I dig it!
    Don, how 'bout some details on that thing?
  29. Six Ball
    Six Ball
    from Nevada
    The 1907 Thomas Flyer that won "The Great Race" had a 571 inch 4 cylinder. Probably wouldn't out run many of the V8s here but it could certainly help some of you settle your size inadequacy issues. It still runs by the way.
  30. Dane
    Dane
    from Soquel, CA
    Only if it was a go cart.
