What would u do with this..1938 Fire truck
Discussion in 'The Hokey Ass Message Board' started by nhmikel, Nov 19, 2012.
  1. Roger Walling
    Roger Walling
    I made a ramp truck out of a 56 F750 fire truck only to find out that the 5 speed transmition was made for city driving in a hill area. First gear is usless. I start in second, wind out third (3500 rpm) and drop into fourth gear ( direct drive) at only 1900 rpm. Over drive only gets me about 60 MPH @ 3700rpm.
    If I do any hills, I must use third for the whole hill and on the level I can go to foruth.
    I am sereiously thinking or a 454 Chevy with an automatic that I took out of a camper.
    The one thing that really breaks my heart is that I have to replace 6 tires that look brand new with only 15000 mi. on them but may be over 50 years old.
    ( The old DOT tire dating system only shows the last year of the decade as no one would have thought tires would last more than ten years)
  2. Roger
    it is not your transmission that is geared low it is the rear end. Most folks don't know it but for a fire truck to run 45 MPH it is hauling ***. They were never intended to run fast, just to get there is all they were ever intended to do.
  3. Rickybop
    Rickybop
    Use the body for a cool pickup truck...and the ch***is for a giant speedster.
  4. nhmikel
    nhmikel
    from NH
    Awesome .....keep the ideas coming
    Believe me I have some more of which will
    be discussed soon
  5. colordeluxe
    colordeluxe
    How much does it weigh?
  6. Normbc9
    Normbc9
    Do what you want and then get hooked up to the local fire apparatus restorers shows. I do and it is really a hoot. '27 Morelands? 28 Studebaker straight eight trucks, 29 Seagrave inline fours with individually cast cylinders. Lots or unusal things to see. My favorites are a 26 Stutz fire engine and a 29 Packard fire engine from Santa Barbara City FD. Once in a while a V-16 Cadillac shows up too.
    Normbc9
  7. tb33anda3rd
    tb33anda3rd
    hence the nickname; "foundation saver":D
  8. hedtedjr
    hedtedjr
    from Central NH
    Personally, I think it would look BA with a couple vintage Harley's in the back headed to Laconia. Just my $.02
  9. DAVEG2
    DAVEG2
    I vote for car hauler.
  10. sololobo
    sololobo
    Is it a G.M.C.? I couldnt see much marking, thought Chevy first and then second thought G.M.C would make more sense. It's cool, not sure what I would do with it. Outstanding spotlight on there! Thanx for sharing this unique vehicle. ~sololobo~
  11. stude_trucks
    stude_trucks
    Nice. One of the best and most useful firetruck rehabs I think I'ver ever seen.
  12. jim_ss409
    jim_ss409
    Here's a photoshop of a firetruck that someone on the HAMB did.
    I think it's interesting that the smaller rear tires look fine.
    I used a Mack firetruck to make this pickup truck.
    http://www.jalopyjournal.com/forum/showthread.php?t=439617&showall=1
    If I had that truck, I'd probably make a car hauler out of it and get a wrecked one ton truck with a duramax for the powertrain.
  13. Stevie Nash
    Stevie Nash
  14. Diavolo
    Diavolo
    If you plan on driving it at all, you can pretty much forget the current setup. I recognize 5 bolt widowmakers a mile away. Also, gearing is going to flat **** so forget anything resembling highway speeds. Your best option is to find a newer utility truck or something and swap frames or do what I am doing this winter and drop the cab onto a 1 ton dually frame and build a bed for it. At least that way you would actually be able to drive it.
  15. deviantdrummer
    deviantdrummer
    from Wylie, TX
    I was thinking "Widow Makers" too. Those things scare the mess out of me.
  16. stude_trucks
    stude_trucks
    No, don't need to do the whole ch***is swap thing which usually ends up with track widths and wheels that don't look right. You can easily swap to similar 5 lug ring wheels that aren't the 'widow makers' and are perfectly safe or even use older solid wheels. Studebaker used them a**** others. The Ford ones are the dangerous one though from what I understand. You can also swap the rear for a 5-lug Dana 70 out of an early 70's Dodge ch***is RV and get a great rearend with tons of gearing options and better brakes. Then drop in a suitable motor and trans of choice, upgrade the master cylinder to a dual and your almost done with the ch***is.
  17. Skeezix
    Skeezix
    from NorCal
    Will work for souls
  18. I would build a traditional hot rod out of it.
    Oh wait... no I wouldn't... because YOU CAN'T... it's a ****ing FIRE TRUCK.
    Sam
  19. slammed
    slammed
    An LS1 would make it bad ***.
  20. 60galaxieJJ
    60galaxieJJ
    go for it free use to all hamb members lol :D
  21. 65stepside
    65stepside
    I hate to jump on the band wagon , but my first thought was "car hauler"
  22. Muttley
    Muttley
    Barney Fife ****s......................try again, this time with Jack Webb.
  23. alexasthoma
    alexasthoma
    from new york
    Hire clowns or Shriners. Done.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  24. 49styleline
    49styleline
    that thing would make a great car carrier
  25. pontman
    pontman
    make sure the pump works, it will be the ultimate rolling squirt gun
  26. Diavolo
    Diavolo
    Oh and by the way, if you are concerned about track width. What I am working with is a 55 F600 former grain hauler. I measured the track width and researched it with the internets and the track width of my 95 F350 dually frame is almost exactly in between the track width of the 55 F2-3 and the 55 F6-7. I thought about just swapping front and rear axles (going to be a towing 4x4 dually, not lifted) but two things surfaced.
    1. Frame is pretty jacked up.
    2. I would have to fabricate all new mounts, fabricate a steering box mount from scratch, run all the lines, etc.
    For all the work, it is just more cost effective time wise and money wise to just drop the cab on the newer frame. All the stuff is factory ***embled and I can get things like a 5th wheel hitch and towing accessories that fit this frame without fabrication. I know I do good work but I still would rather have factory ***embled stuff that is rated for 10,000+ pounds by engineers and not by me guessing.
    Also, I can get a easy to install kit to turn my new(er) truck frame into a 10 bolt with 19.5 wheels and OTR tires to approximate the original profile if I find I want to go that route.
    Just some more things to think about... :)
  27. oldfart36
    oldfart36
    Send me the Spot Light and Siren!
  28. jratz1966
    jratz1966
    I'm in for a hauler
  29. 34 Hound
    34 Hound
    Channel, section and chop it, loose the hood. Blown Chev BB and bad*** pipes.
  30. 34 Hound
    34 Hound
    A fine looking hauler:
